Tutorial DIY 3D printed Sim Racing Hydraulic pedals SRT
Discussion in 'DIY peripherals' started by Lebois, Jan 26, 2020.
  1. 7HUND3R
    7HUND3R Active Member
    1,159Coins
    Well, I will use the P1 together with the GT. I have already asked for a budget to see how much it costs to print everything.
  2. 7HUND3R
    1,159Coins
    I have already asked for a price so that they only print the brake and they charge me 200 euros for the brake pedal and support of the master cylinder and the pedal plate.
  3. 7HUND3R
    1,159Coins
  4. Lebois
    Math teacher
    2,559Coins
    I personnaly use an Ender 3, and I would higly recommand you to buy one ! It would be paid for just by printing those pedals ! And then you would be able to :
    - print newer versions
    - print broken parts if breaks occur
    - print other things (H shifter, steering wheels, paddle shifters)
    You can use any PLA you want. I always buy the cheaper.
  5. 7HUND3R
    1,159Coins
    But is it difficult to handle that model of a five-way printer?
  6. Lebois
    Math teacher
    2,559Coins
    I wouldn't say that it is plug and play. You will need to tune it if you want it to work perfectly... But once you got it, you are good to go !
  7. 7HUND3R
    1,159Coins
    Can you put a video to see the brake in action?
    I already have the brake pedal lever echo.
  8. Lebois
    Math teacher
    2,559Coins
    @7HUND3R you can see it there at11:30 :
    I will do more videos with the next updates
  9. 7HUND3R
    1,159Coins
    It looks perfect. I like that it is soft at first and then later it gets harder on the last hit.
  10. Lebois
    Math teacher
    2,559Coins
    With this pedal, you can set it up as you want, and still have a realistic feeling :)
    I am working on adding other options for the master cylinder : willwood, apracing...
  11. Lebois
    Math teacher
    2,559Coins
    Working on a logo for the P1 pedals... but I think this one is too abstract ^^
  12. 7HUND3R
    1,159Coins
    It looks much improved
  13. Lebois
    Math teacher
    2,559Coins
    I think I should upload accelerator GT v5.8 tomorrow
  14. 7HUND3R
    1,159Coins
    Can the pedals be mounted upside down? my question is what happens to the master cylinder, if I invest it, would the deposit remain face down?
  15. Lebois
    Math teacher
    2,559Coins
    no, the master cylinder can't be inverted, the oil would leak... Otherwise I could add an inverted master cylinder support.
  16. 7HUND3R
    1,159Coins
    The downside to the inverted cylinder mount is that the master cylinder mount would have to be redesigned.
  17. Lebois
    Math teacher
    2,559Coins
    It's not a problem to redesign it. The bigger problem is that inverted mounting plate designs vary a lot, so I don't know how the master cylinder mount should be fixed...
  18. Lebois
    Math teacher
    2,559Coins
    Last version online !
  19. 7HUND3R
    1,159Coins
    the quality of the printer looks fantastic. the only bad point is that having so many colors of pieces it looks like a toy
  20. Lebois
    Math teacher
    2,559Coins
    Well I a way of course you are right.
    But in a way, I like it this way.... it's a touch of derision compared to very expensive full metallic pedals sets :)
    (and I burn off a lot of PLA for my tests. Once it's right, I can print a new one just to do photos :/).
    Second lever for the P1 accelerator :
