2DOF PROJECT - BRAZIL / PROJETO 2DOF - BRASIL
Discussion in 'DIY Motion Simulator Projects' started by Marcos73, Mar 12, 2020.
  1. Marcos73
    Marcos73 Member
    100Coins
    EXTRA - COOLING SYSTEM
    Flexible connections, PVC Ø75mm and aluminum container.
  2. Marcos73
    Marcos73 Member
    100Coins
    EXTRA - DAMPING SYSTEM
    PVC connections Ø32 and Ø25mm, spring and M6 bearings.
    153,824Coins
    +11,151 / 57 / -2
    I am curious as to how the springs behave under load, it would be great to see a video of your rig in actions, when you get the time.
  4. Marcos73
    Marcos73 Member
    100Coins
    Yes, I will soon post the video as soon as I adjust my cockpit.
  5. Marcos73
    Marcos73 Member
    100Coins
    Hi!
    Look. ;)
  6. Marcos73
    Marcos73 Member
    100Coins
    Hello, please help, I test my engines on the SMC3, start the cycle but stop, it seems that they lose strength, does anyone have an idea of what it could be?
    The engines are weight free in this test.
    Thank you.
  7. janio
    janio janio from brazil
    state employee
    belo horizonte
    184Coins
    hello friend, i'm another brazilian from belo horizonte conducting my project. only for vr flight, mainly dcs world. good to know that the brazilian community is growing.
  8. Marcos73
    Marcos73 Member
    100Coins
    Hello, good luck with your project and we will exchange our experiences.
  9. Marcos73
    Marcos73 Member
    100Coins
    UPDATE - ENGINES AND H BRIDGE
    After several tests, the change in electronics and part of engines proved to be inevitable.
    The PONTE H MONSTER showed variations and problems, replaced by PONTE H BTS7960 43a.
    The engines were weak, replaced by 12v 30RPM.
    After several tests with the new update the system operated without fail and perfectly copying the telemetry of the game.
    The change in the connection is necessary!
    My project was excellent with the new updates.
    Good luck to everyone! ;)
  10. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,395Coins
    Glad to see your are building a metal rig and welding it. I too finally bought a welder etc to make my rig and I was super happy with the purchase! Good luck and hope to see you post a video of your Rig running! DMAX
  11. Marcos73
    Marcos73 Member
    100Coins
  12. Alexandre Osmano
    Alexandre Osmano New Member
    Designer
    Brazil
    7Coins
    Ola amigo, estou fazendo meu projeto e precisava de algumas informações, onde vc comprou estes mancais?
  13. Marcos73
    Marcos73 Member
    100Coins
    Hello. Very welcome, if you refer to the bearings, I bought it in a truck parts store, it’s the Mercedes goods clutch.
    Don't forget to always communicate in the English language.
    Good luck.
  14. Pablo Cruz
    Pablo Cruz New Member
    70Coins
    Thanks man, i'm starting my project based on yours.
  15. Marcos73
    Marcos73 Member
    100Coins
    Hello. Follow and it will work perfectly. Good luck.
  16. janio
    state employee
    belo horizonte
    184Coins
    hello marcos, i came back to see how your simulator was, finally mine is finished, it's working great. in your simulator the footrest doesn't follow the movement, don't you feel that it breaks the immersion a little? I also used springs on mine to compensate for the weight of the body on the slope.
    Now all ready, let's fly nice (or run).
    See you.
  17. Carlos A A Bruschi
    Carlos A A Bruschi Bruschi
    Brazil, São Paulo
    155Coins
    2DOF, 3DOF, Arduino
    Marcos your project is amazing. I'm from SP and I want to start mine next year. I'll start by buying the parts and making the electrical connections to test. Then assemble the structure. In fact, there are some pieces there (plate) that have a different format. Do you have a mold with their shape? Thanks.
  18. Marcos73
    Marcos73 Member
    100Coins
    Hello, thanks for liking my project, I did to understand more about electronics and this interaction with mechanics, because I work with projects. Pass your number so we can talk to you.
  19. Carlos A A Bruschi
    Brazil, São Paulo
    155Coins
    2DOF, 3DOF, Arduino
    Hi Marcos, I sent you a message with my whats number.
  20. marcosrobert
    marcosrobert New Member
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    Your electronic project is working
