Power Config for New PT 3DOF Setup
Discussion in 'Commercial Simulators and Peripherie' started by Globespy, Jun 12, 2020.
  1. Globespy
    Globespy Member
    656Coins
    I posted a question in another thread, but to avoid it getting lost in there, I thought I would ask in a separate thread.
    I am awaiting arrival of 3x150mm stroke PT actuators for a racing rig.
    I plan to house the servo controller boxes and a power strip/surge protector/EMI+RFI eliminator in a dedicated enclosure (6U network enclosure).
    Like most homes in the USA, outlets are on 15A circuits - my basement remodel has 20A for all outlets, but I guess that most will be on 15A circuits unless they add brand new wiring/sub panels which can be a major job if sheetrock needs to be pulled out to add the additional wiring.
    I've ordered a 15A power strip as I also have a Simucube DD wheel on the same electrical circuit.
    So, what are most using? Will a 3DOF system work ok on a 15A circuit?
    I can order a 20A power strip since my outlets are on 20A, but then I would need to change the receptacle to Nema 5-20R with the 'turned' post, but not sure if it's even worth it, especially when I have that additional Simucube Servo motor on the same 20A circuit?
    I should have asked about all this before buying, hopefully I am not in for some bad news as I really can't start pulling out walls and ceilings to add a dedicated 50A circuit just for the 3 actuators and will likely just sell the kit if I need to do that.
    Seems Thanos just has his stuff plugged into the wall using regular UK plugs with 4 actuators so hopefully I am good to go!
    Appreciate some insights and feedback!
  2. Thanos
    Electronics Engineer
    2,854Coins
    These servos are efficient. You won't reach their peak current ratings, unless you manage to stall all motors at once at 300% of their rating! Usually the whole system draws 1 to 5 amp, with peaks up to 10A on rough driving profiles. But nothing to trip a 15A circuit. So you can plug the whole system into a single wall outlet without problems.
  3. Globespy
    Globespy Member
    656Coins
    Ahh!!! Thank you so much! I was worrying about having to buy $300 'power conditioners' or since I have 20A outlets, get the 20A power strip with surge protection.
    Sounds like the 15A option I chose with EMI/RFI protection and 3000 joules surge protection should be just fine!
    But I will get a 20A Nema 5-20R option to provide a little more headroom since I have 20A circuits for all my outlets in the newly remodeled basement. This has 1800 Joules surge protection and 400V clamp
    amazon.com/gp/product/B00077IS32
    Plus, my new Subpanel installed in the basement has AFCI breakers which are far safer than the older breakers.
