DIY Pedals & Buttons Controller
Discussion in 'DIY peripherals' started by TOPMO3, Jul 30, 2016.
  1. Nick Moxley
    So you Soldered all the wires properly this time ? Did Flux help like i said it would ?
  2. Nick Moxley
    So you programmed the board with the firmware on the "programmer" then you unplugged the programmer and plugged into the Regular USB Micro and Its not registering ?
    Does it make the USB beep Boop sound ? Can you see anything in the device manager ?
    Just to confirm your flashing .16 firmware ?
  3. Rooligan
    Rooligan New Member
    Web developer @Qoden
    Goor, Overijssel , Holland
    367Coins
    Thank you for taking a look at this. :thumbs
  4. thecures
    thecures New Member
    68Coins
    in device maneger i see marple mini
  5. alberto_sv86_
    alberto_sv86_ New Member
    155Coins
    Good afternoon, with the stm32 could you connect 9 encoders, 16 buttons and a nextion screen?
  6. Nick Moxley
    No Stm cannot run a Nextion
  7. alberto_sv86_
    155Coins
    But could I connect everything I've said before?
  8. Nick Moxley
    Yes it can run encoders and a Bunch of buttons no problems.
  9. tag141
    tag141 New Member
    Tinkerer
    South Walesish
    - 2Coins
    I've just discovered this board and it looks great with the software. But I can't get potentiometers to work either. I've connected A0 to output, Pos to pos and neg to ground. The software I've set pin A0 to analog medium smooth but I don't have any output readings.
    Any ideas I can try. Otherwise it's a top board.
  10. f1simgames
    f1simgames Member
    516Coins
    As i write before , STM32 controller with plastic reset buttons not work with analog devices.If you see , those controllers not have the original STM32 chipset.
    Only STM32 controllers with round metal reset buttons works.They have original STM32 chipset.
    Those are photos of two controllers. First works , Second not!
  11. tag141
    tag141 New Member
    Tinkerer
    South Walesish
    - 2Coins
    I read this whole thread and didn't see where that was written.
    Mine has a square reset, so bang out of luck. Luckily they are cheap.
    cheers
  12. Adrian Culda
    Adrian Culda Member Gold Contributor
    Jack of all, Master of a Few
    Leduc, Alberta
    647Coins
    Any future plans to support the newer nRF52840 Chipset found in the newer generation of Nanos ??
    Would be a definite improvement to move to the much faster Nano 33 BLE not to mention would have such options as UART, SPI and I2C even could be an option for those that want a wireless wheel with a Nextion screen over UART, not to mention use with Load Cells for those that want to use it as pedal box controller, in reality oprtions would be limitless.
    Just my 2 cents though...
    When it comes to Coding, Arduino or any Programming Language I'm lost and always looked at what the masses had to offer because otherwise I am lost LOL
  13. reddo
    reddo New Member
    Nederland
    267Coins
    Tried a round & square button STM32, sadly, both don't seem to read analog input. Now using an Arduino instead and that works fine but I'd rather run the STM32 with OSH Studio to be honest for the extended functionality and software.
  14. jimbraj
    jimbraj New Member
    NJ
    116Coins
    anyone have issues with .15 firmware. I can flash the firm ware but on some versions of the board when i save the inputs as soon as I unplug the stm from USB it resets to single button grd on all pins. Ive tried 3 or 4 different boards all with the stm chip / plastic / metal reset only my older boards work on .15
  15. MartijnV
    MartijnV New Member
    59Coins
    Could someone help me on my way?
    I've ordered a board to replace the stock fanatec PCB on my CSP-v1.
    I want to use the stock load cell and two new hall sensors.
    What's the best way to wire them?
  16. razzor13bt
    razzor13bt Member
    automotive technician, sales manager.
    Durban, South Africa
    393Coins
    hi all.
    I have not had time to finish my setup in months.
    I will be on leave soon due to current world situation.
    What would i need to make 1 input work off of a loadcell for a brake pedal and a 2nd loadcell for a hand brake lever ?
    Would i just need to put a loadcell circuit in series ?
    i am building my own pedal set and contemplating making the electronics a extension of the button box to simplify using 1 usb input on my pc.
  17. f1simgames
    f1simgames Member
    516Coins
    have anyone solve the problem with analog inputs?
  18. Raumo
    Raumo New Member
    56Coins
    I bought a black pill (STM32F103C8T6) to try analog with and I have only tested a potentiometer and it worked fine.
  19. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    does that mean that games such as GTAV will recognice it as a gamepad? I want to make a wheel for GTAV that works as an xbox controller. Arduinos are the other option but I didnt see any tutorial yet. At least not a tutorial for wheels and pedals with potenciometers and everything. Thanks
  20. Mikeness
    Mikeness New Member
    26Coins
    If anyone is stuck with a bluepill with plastic reset button and cannot get the OSH studio working, the Freejoy software/firmware does work with the bluepill with square plastic reset.
    I tested it on my own bluepill that would not register any analog inputs in the OSH software.
    I am unable to add a link due to a new profile, but a quick google search for STM32 Freejoy will send you on the correct path.
