Request (Feature) Total profile fast swap
Discussion in 'SimTools Pro & Entertainment Version' started by PetroVitallini, Jun 7, 2020.
  1. PetroVitallini
    PetroVitallini Member Gold Contributor
    Norway
    248Coins
    Hi!
    I have a bad case of tuningtitis. In regular intervals I try out new tunings where I change the speed and acceleration on my actuators and do the whole tuning session from scratch. This leads to a few challenges. With different games I run different speed and acceleration that I sometimes forget to set because I have to change it manually. It would be great to be able to make profiles that saves every setting. Tuning center values,axis values and interface settings. Because I try different settings and TC and axis values change a bit dependent on the speed and acceleration set, setting and comparing tunings back to back is a bit of a chore.
    I would love for simtools to have a total profile mode or something of the sort so that I could switch between my different tunings with a few clicks when I want to compare.
    Ok, that's the request.
    Have a nice day!
    Petro
    153,001Coins
    +11,116 / 56 / -2
  3. PetroVitallini
    Norway
    248Coins
    I don't like the game manager profiles because I can't see the real tuning center values while changing. I find it easier to understand what's going on when I observe and tune in the tuning center. I've spent a lot of time tuning my rig and I follow the steps in the link you posted.
    As I said, on my prosimu rig I can change the speed and acceleration in the interface settings. As I run some profiles with different speed and acceleration I have to change this manually. It's not a big deal and what I ask for would definitely fall under the category of quality of life. As I don't use the game manager profiles much I don't do the intended workflow in simtools it seems. Just thought I'd ask.
    153,001Coins
    +11,116 / 56 / -2
    Flagging your suggestion for @yobuddy to consider.
  5. PetroVitallini
    Norway
    248Coins
    Thank you!
