Hydraulic pedals DIY
Discussion in 'DIY peripherals' started by Sieben, Nov 6, 2018.
  1. Sieben
    Sieben Active Member
    2,241Coins
    Hello.
    This is the first variant of the pedals being build.
    Then made it on the real pedal block. Get rid of the slave working cylinder for brake, just a direct connection to the pressure sensor. Clutch with hall sensor in the working cylinder. Throttle with wire and a POT.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    • Like Like x 6
  2. Sieben
    2,241Coins
    Some enhancements )
  3. Sieben
    2,241Coins
    Real throttle arrangement from VAZ, with contactless throttle position sensor, as a gas axis input for simulators.
  4. Sieben
    2,241Coins
    Update, update, update [​IMG]
    Brake "set up" applied pressure - 40kg. Sensor itself is on 70 kg.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  5. 7HUND3R
    7HUND3R Active Member
    1,159Coins
    I see in the video that the brake pedal has barely traveled. The truth is that I prefer that the brake pedal has a lot of travel.
  6. Sieben
    2,241Coins
    For what?
  7. 7HUND3R
    1,159Coins
    Because when I touch the brake I like to have a route, because if it doesn't have it it seems that I'm not stepping on anything.
  8. Sieben
    2,241Coins
    Ok I see. Yes, tastes differ then anyway) I like this move on brake, so that's ok too. Anyway it all can be set with working cylinder etc.
  9. Alesi78
    Alesi78 New Member
    59Coins
    Sieben how do you connect the pressure transducer to the pc? Do I need a program to connect it?
  10. Sieben
    2,241Coins
    A FFB program here itself. It has simple connection of 3 wires. Power and signal.
