  1. Marcos73
    Marcos73 Member
    100Coins
    Hello, please help, I test my engines on the SMC3, start the cycle but stop, it seems that they lose strength, does anyone have an idea of what it could be?
    The engines are weight free in this test.
    Thank you.
  2. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Your green line (the pot feedback) is stopping sending information, or i get it wrong?
  3. Bastiuscha
    750Coins
    But i also have a question that's been bothering me for some time:
    Can someone explain to me what Fpwm is changing in practice? Unfortunately I have not really understood it until today. My frame moves the same, no matter if 5 or 30khz. Will the engines become less hot on less khz? Would be very nice to know from you guys.
    153,764Coins
    +11,149 / 57 / -2
    Fpwm The frequency of the selected Motor PWM. Note Motors 1 and 2 are tied together and will always have the same PWM frequency and have more selection options than Motor 3. This is a limitation of the microprocessor used on the Arduino Uno.
  5. Bastiuscha
    750Coins
    Thanks, but that's not what I meant. What's the difference in practice?
    153,764Coins
    +11,149 / 57 / -2
  7. Bastiuscha
    750Coins
    Thanks! In the comments of this link, i found the answer i searched for:
    "A practical motor behaves roughly like a resistor and inductor in series with a real motor. For efficient operation you need should switch between connecting the motor to the supply and shorting it out. While the motor is connected to the supply, the current will become more positive. When shorted, it will become more negative. Efficiency will go downhill markedly if the current switches polarity, because the motor will spend part of each cycle trying to mechanically fight what it's doing in other parts.
    From the standpoint of the motor itself, efficiency will be at its best when the PWM rate is as high as possible. Two factors limit the optimum PWM rate, however:
    Many motors have a capacitor in parallel with them in an effort to minimize electromagnetic interference. Every PWM cycle will need to charge and discharge that cap, wasting a full load of energy. Losses here will be proportional to frequency.
    Many H-bridge switches take a certain amount of time to switch; while they are switching, much of the power going into them will be wasted. As the PWM on and off durations shrink toward the point where the bridge is spending most of its active or inactive time switching, switching losses will increase.
    What's most critical is that the PWM rate be fast enough that the motor doesn't fight itself. Going faster beyond that will improve motor efficiency somewhat, but at the expense of increase the other aforementioned losses. Provided there isn't too much parallel capacitance, there will generally be a fairly big range of frequencies were PWM losses are minimal and motor current polarity remains forward; a frequency somewhere near the middle of that range will probably be best, but anything within that range should be adequate."
  8. Marcos73
    Marcos73 Member
    100Coins
    Hello, I manually activate the potentiometers and the same effect happens, the motors stop.
  9. Bastiuscha
    750Coins
    Do the switches still stay "on", or they turn into "off"? (like on the picture i created)
  10. yondwangmms
    yondwangmms Member
    - 148Coins
    Very good introductory tutorial, I believe that under the guidance of this tutorial I will quickly complete my motion simulator platform!
  11. Marcos73
    Marcos73 Member
    100Coins
    [QUOTE = "Bastiuscha, post: 200610, membro: 25016"] Os interruptores ainda permanecem "ligados" ou se tornam "desativados"? (como na foto que eu criei) [/ QUOTE]
    Yes, they remain on, and when I operate the pots manually, I cross all limits, but I do not move, it seems that there is not enough energy to move.
  12. Bastiuscha
    750Coins
    Then it looks like it's your motor driver. Or really your power supply is the reason. What you use as driver? There is no error led active?
  13. Marcos73
    Marcos73 Member
    100Coins
    OK, THE SOURCE IS OK, I WILL OPEN THE BOX AND CHECK THE H BRIDGE (MONSTER SHIELD). THANK YOU.
    FOLLOW VIDEO OF ELECTRONICS
  14. Özden Büyüksanalan
    Özden Büyüksanalan Member
    317Coins
    thanks for that great tutorial and how to build.
    I build the Same as Mode 2. Arduino Uno R3 with 2 IBT-2.
    I completely wired one IBT-2 to the motor and the arduino board.
    Before i uploaded SNC3 to arduino. If i start SNC3 Utility i can set all to 0 like
    mentioned in the tutorial. After that i power up the motor.
    I went PWMmax to 255 but the motor do nothing. Only one grey line goes up.
    If i manualy circle the pot the green line is moving.
    Is there something in the settings which i made wrong?
    Greets
  15. Özden Büyüksanalan
    317Coins
    EDIT:
    Nevermind. It is up and running. I now understand max limits and clip. The Potentiometer
    was fully on one side so it allways clips directly without starting the motor. Great.
  16. GoRacing
    GoRacing Member
    96Coins
    DC motor
    Hello @RufusDufus, pure curiosity, I wanted to know why ibt2 feeds with 5v to pins 7 + 8gnd? I tried to remove the 5v from ibt2 + and it works the same.
    Another question: is it normal for all the oscillations of the PWM and the potentiometer? as can be seen from the screenshot. Then in the engine it makes noise even when I put it in manual and it is stopped. I tried to lower kp from 400 to 300, but only if I lower it to 200 does the noise disappear but the engine becomes slow. If I raise the minimum PWM it makes even more noise. What can it depend on? Thanks in advance
  17. MrDemon
    MrDemon New Member
    - 84Coins
    Hello. I have a serious problem. It seems like everything works. Everything works fine in the SMC utility, but when I load simtools game engine the platform movements become very strange. When I start output testing and start moving the sliders, with a value of "1" the platform moves almost to the maximum and the difference between the values of 1 and 100 is not very significant. I have a 2dof platform. It's almost impossible to play. The platform jerks from one maximum to another (((Once again, in the test utility, everything works smoothly and the platform deviation angle is correct. The SMC and SIMTOOLS "centers" are different. That is strange too ((((
    When I take the slider in simtools to minus, it works from zero of simtools . When I take the slider to plus, it seems to work from zero SMCUtil. The difference between zero of simtools and zero of SMCUtil is this jerk. :sos
    As I see it - the problem is just in different centers between the simtools and SMC .
    SOLVED You have to change Win Regional Settings to English )))))
  18. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Can use this this code with DIY linear actuator(use slide potentiometer to feedback position)
  19. physke
    physke New Member
    IT & Electronics Engineer
    Tauranga, New Zealand
    192Coins
    Arduino Leonardo doesn't have Timer2, so change TCCR2B to TCCR3B in the code.
  20. MuñozChile2dof
    MuñozChile2dof 2 DOF SIMULATOR ARDUINO AND IBT-2
    Hydraulic technician
    CHILE
    54Coins
    Hi, i have a problem :( I use Arduino uno and two Ibt-2 h bridges
    A while ago I got my simulator to work perfectly, but I had problems with my computer and had to update some parts. A few days ago I assembled my new computer, installed windows, and again downloaded Simtools, the SMC3 software and the respective arduino code. With all that ready, I set the parameters and opened a game but the movement was erratic. I disconnected the levers that connect with the seat and tested the movement only of the motors, finding that the motors do not make the braking movement, only acceleration, this happens when having the axis limiter at 30%, this is how I had configured it previously And it worked perfect, these days I have been doing tests but the only way in which I get the braking movement to occur is by raising the axis limit to 100%. I will leave some pictures of my configuration, I would appreciate if someone can help me with that.
      119.6 KB
      568
      120.2 KB
      498
      113.2 KB
      518
      81.4 KB
      507
