$450 Mige Direct Drive Wheel using MMOS and AASD
Discussion in 'DIY peripherals' started by Peacemaker105, May 6, 2020.
  1. DJ_BLAZKOWICZ
    DJ_BLAZKOWICZ New Member
    IT TECH
    Scotland
    266Coins
    My 90ST-4025 is getting shipped. Mega excited to try this! I'm planning to use a 3d printed pla shaft adapter to attach a wheel to the motor, should I be worried about material strength?
  2. diggumwood
    diggumwood New Member
    92Coins
    The AliExpress sale? I'm also very probably going to click by tomorrow on the same unit.
    My plan is a 3D printed shaft adapter, but I was thinking of going with petg because it's got a bit more give to it and the high-frequency bumps and shakes of the motor might eventually cause a cracking pla.
    It should be strong enough though, if you make it heavy duty enough in terms of plastic and don't over torque any nuts
  3. DJ_BLAZKOWICZ
    IT TECH
    Scotland
    266Coins
    Yes it's from the BST Automation sale on Aliexpress! :)
    I'll see how I get on with the pla design once I've got everything here and share my progress.
  4. Datch
    Datch New Member
    Moscow, Russia
    115Coins
    I used PETG and ABS for adapters for my 90st-04025 servo. I've broke ABS one because of not using clamp. PETG one seems to have some gap after 2 weeks of use. I think that it's better to use ABS for adapter because my servo shaft heats up to 60-70 Celsius degrees.
  5. ajosesi
    ajosesi New Member
    85Coins
    How satisfied are you with the 90st? Did you wish you went with the bigger one? Braking adapters sounds plenty of force...
  6. diggumwood
    92Coins
    Ok me too. I just clicked buy. COVID finances were harder to convince than the wife! Time to really start accumulating bits for the rig :thumbs
  7. DJ_BLAZKOWICZ
    IT TECH
    Scotland
    266Coins
    I think my disco board arrived today. The motor should be here by thursday.
    Started making an adapter for my 40mm m6 bolt pattern gokart wheel.
    The 90ST has 16mm shaft diameter right?
  8. DJ_BLAZKOWICZ
    IT TECH
    Scotland
    266Coins
    Ok so my stuff is here. But I realised I gave all my bar clamps away and I have nothing to bolt the motor onto..
    Gonna try to make a mount with my friend in our spare time the next couple of weeks.
    Motor feels quite strong i stupidly started jog testing it while holding in my hand and it almost jumped out of my grip :D
    I made a pla shaft collar, will see how long it takes for it to melt!
  9. DJ_BLAZKOWICZ
    IT TECH
    Scotland
    266Coins
    got mmos sorted and wired up and the motor just keeps spinning into one direction. Tried changing pn191 but all it does is switching the direction of the spin. any suggestions?
    EDIT: i probably should not be using jumper wires to connect the stm board to the db25 cable.. i think it's my bad wiring causing an issue
  10. ajosesi
    ajosesi New Member
    85Coins
    And did you get it sorted? Do you use Thanos 407 board?
  11. DJ_BLAZKOWICZ
    IT TECH
    Scotland
    266Coins
    I haven't had time to touch it since. I don't have a Thanos board, using an stm32f-407-disc1.
    Waiting for some supplies to arrive so I can make better contact between the disco board and the aasd box.
    UPDATE: i soldered the wiring properly to a db25 connector. reset the aasd drive, input the proper settings again. I had to set "reverse encoder" in mmos. The motor stays centered on powerup now. :)
  12. DJ_BLAZKOWICZ
    IT TECH
    Scotland
    266Coins
    So i hooked up everything to my desktop for the first time.
    The machine's usb controller freezes as soon as I turn the wheel and comes back to life if the AASD gets disconnected from the disco board.
    I'm assuming this is a grounding issue with the motor so I'll try to sort that out in the next couple of days.
  13. Gadget999
    12,307Coins
    what type of wheel is that you have ?
    where did you get it ?
  14. DJ_BLAZKOWICZ
    IT TECH
    Scotland
    266Coins
    It's a gokart wheel, i think i got it on amazon or ebay. You can find the same design here and there if you search "f1 style gokart wheel". I want to make a proper hub with buttons and shifter+clutch paddles for it once the steering works reliably.
    One thing to note, it has a 40mm triangle bolt pattern, so not sure if it will fit a universal quick release.
    I will release 3d model files for what i designed for it at some point.
  15. DJ_BLAZKOWICZ
    IT TECH
    Scotland
    266Coins
    Well, I moved the usb hub from the front panel to the rear and I no longer get usb issues seemingly.
    But I'm only running 15% force as I haven't got the desk clamp built yet!
  16. Gadget999
    12,307Coins
    looks like a good basis for a sim wheel - some panels and buttons it will look the part
  17. Thanos
    Electronics Engineer
    2,917Coins
    I ordered a sleeve adapter from 16mm to 19mm
    https://www.ebay.com/itm/5-8-to-3-4...er-Sleeve-Bushing-With-3-16-Key-/264601441495
    So I can use the Ascher racing servo clamping set + 70mm adapter I got...
    https://www.ascher-racing.com/shop/clamping-set/
    And perhaps add a quick release as well :
    https://www.ebay.com/itm/143634821596
  18. DJ_BLAZKOWICZ
    IT TECH
    Scotland
    266Coins
    started designing a 3d printable bracket using some bessey tk6 clamps. will probably warp due to heat on higher ffb % but does the job for now and I will be adding a 120mm cpu fan.
  19. Peacemaker105
    Perth, Aus
    2,034Coins
    Want a cheap Bluetooth Button box to compliment your new DD wheel? Finally did a little video of the BlueHID wheel i built recently. Such an awesome little device to work with!
    • Winner Winner x 3
  20. Gadget999
    12,307Coins
    Looking good !
    Hope to get my wheel operational asap. Likeing the bluetooth buttons :)
