Question Is this motor any good for a direct drive?
Discussion in 'DIY peripherals' started by neportocala, Jun 21, 2020.
  1. neportocala
    neportocala New Member
    52Coins
    I searched the local second hand market and I found this motor
    From what I found online in the official documents, it has a sincos single-turn encoder (1024 phases per revolution)
    Here are some details about the motor:
    I have a question as well, does 400V mean that I should connect it to a 400V supply or that it's the max the motor can handle?
    Please tell me if this motor is a good deal for 80 euro.
    Thank you!
  2. neportocala
    52Coins
    Here are some more specs, seems I cannot post links yet
  3. neportocala
    52Coins
    And a torque-speed graph - it also seems that you can connect it to normal household 230V socket. Also, can you control it with IONI?
  4. Gadget999
    12,132Coins
    it looks pretty good
    does it come with a motor driver ?
  5. neportocala
    52Coins
    It doesn't, do you think it would be hard to control with a 3rd party controller such as Ioni?
  6. Gadget999
    12,132Coins
    you may need other parts like a power supply etc if you use ioni - best to find a complete solution
