Problem motor 1 in 2DOF
Discussion in 'DIY Motion Simulator Projects' started by sbdtoni, Jun 21, 2020.
  1. sbdtoni
    sbdtoni Member
    207Coins
    Dear friends, I am testing the motion 2 dof and I have a small problem, it turns out that the motor 1 when I put my back on the seat gives small jingles, it is as if the potentiometer made the motor return to the center, everything else works but that does the motor is not normal, changed the potentiometers and keeps doing it and only motor 1, does anyone know what I can do?
    Greetings
    154,400Coins
    +11,181 / 57 / -2
    Have you tried a little dead zone in SMC3?
  3. sbdtoni
    sbdtoni Member
    207Coins
    No,
    hi Noorbeast no I’ll tried next week, thanks for your help best regards
  4. sbdtoni
    sbdtoni Member
    207Coins
    Hi Noorbeast this is a video with the problem that i have ( i not make the test with dead zone)
    thanks for your help.
  5. susocalfail39
    susocalfail39 Member
    GALICIA, ESPAÑA.
    50Coins
    To reverse the movement of the motor and match what you want me to do, mark the box attached to the image, in the case of a roll, one motor has to go up and another go down as I mark it, in other effects not because I want it to go up the same, it depends on what you are looking at, also make sure that you get the signal from the potentiometer, from the software in the appropriate position, turning it to one side or the other so that it stays lifting from the side you want, the better potentiometers with hall sensor because if they are not going to break, I have them homemade, but for that matter they are worth me and I have greetings to spare. use traslator. simtools.png
  6. susocalfail39
    GALICIA, ESPAÑA.
    50Coins
    or I think that according to your back and forth movement, the potentiometer is broken and tends to spin the motor uncontrollably, since you have to check with the adjustment software in my case I use smc3, which detects the green line, which is what it will indicate to the engine where it has to be stopped, it is the most important and each engine is a world and you have to adjust values and understand this so that it goes well, this is the most important, I attach how it looks like my homemade potentiometer detects the signal and as I have changed values so that my engine feels good, this is the most important part, then there is the tuning center within the simtools software, but that is another story, make sure that it detects all the lines well on the smc3 before starting simtools, You only have to do it once and it stays with you.
    As you can see Motion frame to start moving the motor simulating a movement,
    At the beginning it is in monitor mode and it does not move, only if you turn the cranks by hand you will see the green line move and by the way the motor following the green line, if you mark square it will make movements up and down following a square wave, send A capture of how it does it, if you do not see the green line or it moves without being in time with the others, it is that the potentiometer is broken or a disconnected signal cable, take a good look at this is the first step before starting the program.
  7. susocalfail39
    GALICIA, ESPAÑA.
    50Coins
  8. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    Hi @susocalfail39
    The forum rules were changed a while ago and now only allows the English language when posting. You can use google translate but only post the English translation. This was done to stop threads in multiple languages that were hard to follow. Also members were duel posting to double there coins haul per post. Your knowledge and help towards other members is always welcome here but if the site moderators delete your post without further asking (as the rule is written) then no one will get the info that you want to add.
    just trying to help buddy.
  9. susocalfail39
    GALICIA, ESPAÑA.
    50Coins
    ok ok sorry, I edit, delete post, only inglish
