Question Help with UDP F1 2019 ProSimu and Monsta Dashboard
Discussion in 'Commercial Simulators and Peripherie' started by Slumpfi, Jun 17, 2020.
  1. Slumpfi
    Slumpfi New Member
    34Coins
    3DOF, Motion platform
    Hello guys, I'm new here and I was hoping you could help me.
    I have a problem that my Sim (ProSimu) does not work with my dashboard (Monsta) in F1 2019. Not in play with UDP 2019. The Prosimu always needs UDP legacy data and the dashboard (Monsta) UDP 2019. Is there a plugin? to download where the prosim works with the UDP 2019 and both go. Or you can specify in the SimTools program that Prosimu works with UDP 2019. But only in F1 2019.
    Thank you and hope the translator is good.
    THX Papa Slumpfi
    153,986Coins
    +11,162 / 57 / -2
    I am guessing there is likely a port conflict, do you know what port the Monsta dashboard is using?
  3. Slumpfi
    Slumpfi New Member
    34Coins
    Hello and sorry, it takes me so long to answer.
    The Port from Monsta is 4 and the port from the Prosimu is 7 and 8, I hope you can help me thx
    153,986Coins
    +11,162 / 57 / -2
    There are exception but generally a game can't output to multiple different ports, just one, perhaps @yobuddy can advise if Monsta Dash can be run via GameDash.
  5. yobuddy
    51,557Coins
    Its hard to support games that have multiple output options (code-master games mostly) + SimTools+ some other app.
    It seems no matter what output type we choose, some other app always uses something different.
    Some want legacy, some others want the most current output type.
    In this case it would take a 2019 f1 with legacy support, I can take a look when i circle back around for v3 plugins.
    Take care,
  6. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    Have you tried a proxi server? most Codemaster games only give you one "signal out" for motion or leds or else. Simhub has it. I used to use this one, also free : http://www.eksimracing.com/cmps/
  7. Slumpfi
    Slumpfi New Member
    34Coins
    Super thanks for the tip and sorry for long answer from me! will try it and then get back to me! THX
