Question Worm Gear and Motors
Discussion in 'Motor actuators and drivers' started by terry wells, Jul 1, 2020.
  1. terry wells
    terry wells Active Member
    retired military
    minnesota USA
    727Coins
    3DOF, Arduino
    Hello all, been a while since I have been on this forum but since the covid thing going on i am thinking about "up grading" my Flight Simulator Motion Platform from winch motors to worm gears and motors and going from "TWO" ( pitch and roll) to three. I am not sure what configuration I would need to do this. The platform I have now is 4 ft x 6 ft and it carries (5) monitors and (1) person I weigh about 225lbs. and the two winch system works well but is very noisy and somewhat jerk-able at cretin times. The downloads show what I have and what I would like to do is at this site.
    Thank You
  2. Gadget999
    12,035Coins
    I use 2 x motors from wheelchairs connected to one worm gear for each axis
    you may be able to use AC servo motors if you want a powerful solution
  3. terry wells
    retired military
    minnesota USA
    727Coins
    3DOF, Arduino
    is this a flight sim or a chair sim you have. what do you mean by AC servo motors
  4. Gadget999
    12,035Coins
    its a racing sim
    AC is the type of current
    Alternating Current
  5. terry wells
    retired military
    minnesota USA
    727Coins
    3DOF, Arduino
    This is not a reply. I was just wondering if anyone in this forum has ever used or considered using NMRV worm gear reducers for a simulator. Please,please let me know if you have. I have questions that I cannot answer about the ones I need to purchase. I don't plan on spending money untill I kinda know what will work. Thank in advance.
    Terry Wells
    152,553Coins
    +11,087 / 56 / -2
  7. terry wells
    retired military
    minnesota USA
    727Coins
    3DOF, Arduino
    Thanks for the quick reply, do you think 3 of those worm gears will work on my platform. (ie, lift and degrees of motion) I will be using 3 reducers and motors.
    152,553Coins
    +11,087 / 56 / -2
    A 3dof is possible, but it is a question of design Vs physics, which determine the motors and ratio needed to drive a rig at a desired performance level.
    So it depends on how you choose to resolve the inherent challenges for a 3dof, and there are different approaches possible, for example with my compact 3dof upgrade I went with assisted heave, 200w motors and 60:1 gearboxes, the assisted heave takes some of the load out of the equation and allows less powerful motors to be used than would be the case with a fully supported traditional 3dof rig.
  9. terry wells
    retired military
    minnesota USA
    727Coins
    3DOF, Arduino
    good to know, do you have a picture of your rig? so when programing the 3dof, what is axis 3 setup for? Now I have axis 1 as roll and axis 2 as pitch. ( using 2 motors/gears)
    152,553Coins
    +11,087 / 56 / -2
  11. terry wells
    retired military
    minnesota USA
    727Coins
    3DOF, Arduino
    looks GREAT! If I were to change over to 3DOF using the worm gear reducers which one would I need to make Roll,Pitch, and Heave looking at my quick drawing?
    152,553Coins
    +11,087 / 56 / -2
  13. terry wells
    retired military
    minnesota USA
    727Coins
    3DOF, Arduino
    These are all seat /racing platforms. I guess I will just have to work it out myself. Thank You
    Terry.
    152,553Coins
    +11,087 / 56 / -2
  15. terry wells
    retired military
    minnesota USA
    727Coins
    3DOF, Arduino
    Some good ideas here. I see that the front of the racing sims has 0ne (1) actuator and the rear has two (2). Would this be the same for a Flight Simulator?? (just opposite of which my drawing shows).
    Terry.
  16. noorbeast
    152,553Coins
    +11,087 / 56 / -2
    It can be either, my compact 3dof has 2 front and 1 rear motor.
    In many respects the motor layout has more to do with the frame design than anything else, as the forces it creates is 3dof irrespective of the motor layout.
  17. terry wells
    retired military
    minnesota USA
    727Coins
    3DOF, Arduino
    If I install my motors and actuators in a triangle configuration, will the smc3 utils and sim tools and p3d plug in code still work( ie, pitch/roll /heave) ?? using no center post
    Terry Wells
  18. noorbeast
    152,553Coins
    +11,087 / 56 / -2
    SimTools, SMC3 and plugins are not affected, it is really a question of design and having enough motor power to drive a unsupported 3DOF rig.
  19. terry wells
    retired military
    minnesota USA
    727Coins
    3DOF, Arduino
    Would the Interface-Output just need to have [C<Axis3>] added in to make 3 motor axis for this setup?
    152,553Coins
    +11,087 / 56 / -2
    Yes, but it should be like this: [A<Axis1a>][B<Axis2a>][C<Axis3a>]
