FlyPT Mover 3.5.3
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    @deadlymanager,
    I opened your conf. file and I don’t see the source (game) and the output (controller card).
    You have first to establish the connection to begin build your profile.
  2. Hershann
    Hershann New Member
    134Coins
    Just received amc controllers and actuators - ready to do the wiring and test setup over the next few days. Should i go ahead with the 2.99 or wait for ver3.0?
    thanks
    hershann
  3. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Just
    - configure your geometry
    - pick up your source
    - choose Thanos as output and you’re ready to go.
  4. Hershann
    Hershann New Member
    134Coins
    Ok! Will ask for help if I meet any obstacles.
    thanks
    HerShann
  5. deadlymanager
    deadlymanager Member
    9Coins
    Very strange. My controller is Arduino Mega 2560 x 3 and driver program absolutly worked as with my solver IK module, so with FlyPT. I Just save .Mover as is.
  6. Victor Urnes
    Victor Urnes New Member
    113Coins
    Motion platform, 6DOF
    We are trying to use the FlyPT mover with a wago PLC. Programmed in CodeSys. We are trying to receive the signal on the PLC via UDP, but are struggling a bit. Have somebody done it before? And how?
    Victor
  7. pmvcda
    15,458Coins
    Did you try to send the udp with another app?
    Was it working?
    Can you share the string command.
  8. Victor Urnes
    113Coins
    No, I havent tried.
    The string command is <Axis1a><Axis2a><Axis3a><Axis4a><Axis5a><Axis6a>.
    I have tried to sniff the output from FlyPT. It sends a short command every time i connect, but nothing more. See screenshot from Wireshark.
  9. pmvcda
    15,458Coins
    Are you expecting binary or decimal?
    Please show me the output window also.
  10. Victor Urnes
    113Coins
    We are expecting binary signals. See screenshot.
    Victor
  11. pmvcda
    15,458Coins
    That start string seems to have a problem...
    11111 should not be just 103, but 103 043
    Try to replace <11111> with <103><43>
    Not sure this is the cause
  12. pmvcda
    15,458Coins
    Or <43> <103>...
    Now i'm in doubt. Not near a pc to test
  13. Victor Urnes
    113Coins
    Sorry. This start string was only for testing. I dont need it for the finish result. I cleared it, and its the same fault..
  14. Victor Urnes
    113Coins
    See this updated screenshot. Same issue with this settings.
  15. pmvcda
    15,458Coins
    Did you gave permission on the firewall for that port?
  16. Victor Urnes
    113Coins
    Yes, same issue. We have a Thanos card laying here, maby we'll just use that...
    Victor
  17. deadlymanager
    9Coins
    Little program for Warthunder. Recieve data from two ingame servers and send via UDP. List all telemetry what WT send.
    • WT.zip
      242.9 KB
      365
  18. Jacominus10
    Jacominus10 New Member
    - 88Coins
    4DOF
    Sorry, but where is the download link for the simtools plugin? i can't find it here and forum plugin page..
    152,535Coins
    +11,085 / 56 / -2
  20. pmvcda
    15,458Coins
    I have already some things done for War Thunder in the new 3.0.
    Do you know how to get data for tanks, or there's no data available?
