Codemasters F1 2020 Plugin v2.0
SimTools plugin for Codemasters F1 2020
  1. yobuddy
    51,559Coins
    yobuddy submitted a new resource:
    F1 2020 Plugin - SimTools plugin for Codemasters F1 2020
  2. Camerus
    Camerus Sim builder
    California
    46Coins
    Motion platform, 4DOF
    Hi Yobuddy! Thanks for having this plugin already up and running. Unfortunately I am going through all sorts of combination to get F1 2020 work with my SFX100. For reference all my games including F1 2019 are working and I have even tried DX11 mode to see if the issue is resolved. I have no telemetry going into Simtool in DX12 or DX11. Even using Legacy mode in the game. I have tried 2020 telemetry down to Legacy with not much success. Any insight into what works? Thanks
  3. AlbertoMoralo15
    AlbertoMoralo15 New Member Gold Contributor
    - 21Coins
    The plugin works perfectly in all modes except in My Team, any help?
  4. Camerus
    Camerus Sim builder
    California
    46Coins
    Does it work on DX12 2020 telemetry for you? If so what setting you are using? I could only get DX11 legacy to work.
  5. AlbertoMoralo15
    - 21Coins
    Only with DX11
    The configuration is the same as the 2019, PM me if you want more info
  6. AlbertoMoralo15
    - 21Coins
    @yobuddy, do you have the game now, and is this problem general or only in my case, I have tried to solve it, but is impossible
  7. Jacominus10
    Jacominus10 New Member
    - 88Coins
    4DOF
    I love F1, but never get simhub/sim racing studio wind/ z1 dashboard and simtools plugin work together since F1 2019, and at this time F1 2020, as usual cannot work together, even I try simtools standalone only, and use default port 20777, dx11 and legacy mode.. no luck, so frustrating
  8. Camerus
    Camerus Sim builder
    California
    46Coins
    Read this article on Codemasters forum https://forums.codemasters.com/topic/50942-f1-2020-udp-specification/to understand how UDP telemetry in F1 2020 works and why using telemetry other than 2020 will limit a few option like having telemetry if you create your own team. I am reading through it to see if anyone is suggesting a solution. I am also going to look at FlyPT for better support for this game.
    • Old Old x 1
  9. alexdraco
    alexdraco Member
    278Coins
    Hi all
    I installed the plugin for F1 2020 and I correctly set the telemetry in the game, but I have a question in the tuning center (values calculated by the game) I have these values:
    Game Engine values:
    Question for those who have tried and have no problems, are my values correct? because from my point of view I feel little roll, but when I touch a curb I fly from the seat =).
    With Assetto Corsa i have no problem.
    Thanks in advance
  10. yobuddy
    51,559Coins
    It depends on what sim you have a bit, but maybe give it a try with just surge, sway and heave to start with.
    Surge and Sway at 50% and Heave at 10% or so.
    See what you think...
  11. AlbertoMoralo15
    - 21Coins
    From my point of view the problem isn´t that, because it works with the 2019 legends cars, it may be a problem of not updating/having the cars text lines becuase Schumachers cars don´t work and all the other yes, so maybe this is a little help @yobuddy . If you could try to make an early access-version with one of the Schumachers cars and we could try. I have not idea of how difficult is to make a plugin, so sorry if my information is not correct.
  12. alexdraco
    alexdraco Member
    278Coins
    i tried your settings but i feel that the sim is moving around like no sense.
    btw i have 2dof sim, i'm still trying to set the value correctly.
  13. alexdraco
    alexdraco Member
    278Coins
    i have heave on 2 and i set on the profile editor -50 because when you touch a curb you fly but once again im flying what i can do?
    153,986Coins
    +11,162 / 57 / -2
  15. Marxman
    Marxman New Member
    South Africa
    - 32Coins
    I have also noticed this, in the single races it is fine but in |My team| there is not motion.
  16. alexdraco
    alexdraco Member
    278Coins
    For my team you have run the game on dx 11 and set the UDP format to 2020, for any races (grand prix,online) you have to set UDP format to legacy =)
  17. alexdraco
    alexdraco Member
    278Coins
  18. fafafoot
    fafafoot New Member
    bruz
    - 165Coins
    Hello
    it doesn't work for me...
    F1 2019 works perfectly i don't understand why f1 2020 not....
    Someone can help me?
    thks
  19. bruno1210
    bruno1210 schumi06
    103Coins
    same setting as f1 2019 !
  20. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    611Coins
    2DOF, 3DOF
    Good morning all,
    I acquired the F1 2020 Schumacher version and I installed the plugin but alas nothing works I started directx11 and made the same adjustments as F1 2019 in legacy ect
    someone would have a solution.
    thank you all.
