Resolved Different axis limiting for each way of a G-seat flap?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Qlittles, Apr 8, 2020.
  1. Qlittles
    Qlittles Active Member
    Union City, California, USA
    226Coins
    Hello all, I'm re-working my G-seat, and I had a question about having different axis limiting for each way of a flap. For example:
    Flap movement "A" is larger than flap movement "B". I want to do this because I realize that although it is possible to just not use the negative value in the Tuning Center, there is some detail I will be losing on the "B" side. I do understand that I can increase the negative Tuning Center value so that "B" is half of "A" for example. However, this doesn't guarantee that the flap won't travel past "B", in which case, things will break mechanically.
    Is there a way to set the axis limiting for the motor for just one direction? Maybe a modified SM3?
  2. Trigen
    Trigen Active Member
    2,891Coins
    The easy way is to go to line 545 (bit below) in the SMC ardunio file and change the minimum axis limit and cropping it. That way you have a hard limit
    Here's mine.
    Code:
    void ReadEEProm()
        int evalue = EEPROM.read(0);
        if(evalue != 114) //EEProm was not set before, set default values
            WriteEEProm();
            return;
        CutoffLimitMin1 = 300;
        InputClipMin1 = 500;
        CutoffLimitMax1 = 750;
        InputClipMax1 = 700;
        DeadZone1=EEPROM.read(5);
        CutoffLimitMin2 =300;
        InputClipMin2 = 500;
        CutoffLimitMax2 = 750;
        InputClipMax2 = 700;
    Another option is to use PT Mover where you can just crop negative wherever you want without any hassle and you can limit each force where you want it. Might not be exactly what you want but give it a look anyways. Its much much faster to check what value your pot is at and is great for testing. There's a remap feature that could maybe be used but i dont quite understand it yet. You also have logistic which is the same as the use % of axis in Simtools
    Here's the link and ive added my config file in the latest mover release so you can just tweak the com ports you need. Be aware you need to change your value range to -100 100 in the upper axis 1 and 2 as i have mine set so that center is at 323 for more range on my hall sensors. Also DO NOT power on or off before turning Mover on/off . PS Roll speed is amazing for Gseats
    https://www.xsimulator.net/community/threads/flypt-mover.13464/
    Im sure some of the great support on here will chip in with some insight too
  3. Qlittles
    226Coins
    Awesome! Thanks a bunch for the detailed response. I'll first try the easy way you mentioned and see if that suffices ( I'm a bit intimidated by the second option).
  4. Qlittles
    226Coins
    Hi! I'm trying to change the values in your first method, but I don't see the code in SMC3 at line 545. Did you put in this code at that place? I'm looknig at the latest SMC3 version if that makes any difference. Also, I see at the beginning of the code CutoffLimitMax1, etc. Is this the right section? Thank you for your help!
  5. Trigen
    2,891Coins
    My bad, it starts at 483, ive just put 545 in as it brings me to the code.
    Here's the default. replace InputclipMin = to fks 512 to have it stop in the middle.
    Code:
     CutoffLimitMin1 = EEPROM.read(1);
        InputClipMin1 = EEPROM.read(2);
        CutoffLimitMax1 = 1023-CutoffLimitMin1;
        InputClipMax1 = 1023-InputClipMin1;
        CutoffLimitMin2 = EEPROM.read(6);
        InputClipMin2 = EEPROM.read(7);
        CutoffLimitMax2 = 1023-CutoffLimitMin2;
        InputClipMax2 = 1023-InputClipMin2;
        DeadZone2=EEPROM.read(10);
        Kp1_x100=ReadEEPRomWord(11);
        Ki1_x100=ReadEEPRomWord(13);
        Kd1_x100=ReadEEPRomWord(15);
        Kp2_x100=ReadEEPRomWord(17);
        Ki2_x100=ReadEEPRomWord(19);
        Kd2_x100=ReadEEPRomWord(21);
        PWMoffset1=EEPROM.read(23);
        PWMoffset2=EEPROM.read(24);
        PWMmax1=EEPROM.read(25);
        PWMmax2=EEPROM.read(26);
        PWMrev1=EEPROM.read(27);
        PWMrev2=EEPROM.read(28);
        PWMrev3=EEPROM.read(29);
        CutoffLimitMin3 = EEPROM.read(31);
        InputClipMin3 = EEPROM.read(32);
        CutoffLimitMax3 = 1023-CutoffLimitMin3;
        InputClipMax3 = 1023-InputClipMin3;
        DeadZone3=EEPROM.read(35);
        Kp3_x100=ReadEEPRomWord(36);
        Ki3_x100=ReadEEPRomWord(38);
        Kd3_x100=ReadEEPRomWord(40);
        PWMoffset3=EEPROM.read(42);
        PWMmax3=EEPROM.read(43);
        Ks1=ReadEEPRomWord(44);
        Ks2=ReadEEPRomWord(46);
        Ks3=ReadEEPRomWord(48);
  6. Qlittles
    226Coins
    YEEEEEEEEEESSSSSSS!!!!! I finally got it to work using your instructions!!! Finally, I'm able to secure the arms without worrying about things breaking :) Thanks a bunch!!!!
  7. FredBasset
    FredBasset Member Gold Contributor
    461Coins
    I'm fairly new to this but have now got my motors moving nicely with SMC3Utils. I'm using BlazinH's modified SMC code with a Sabertooth 2x32.
    I only want "positive" motion on my axis and for any "negative" motion to be cropped. I've tried the modifications mentioned above using 512 as the mid point but if I use SMC3Utils it just continually turns off the motor. I then tried 400 to see if I could at least limit the negative motion but its still not working.
    Any thoughts as to what I might be missing? Also I haven't tried it with SimTools yet, is the cropping only effective there.
    Thanks for any help
    Fred
  8. BlazinH
    16,691Coins
    To crop all negative motion just use the tuning center in Simtools and set the negative values for the dofs you want cropped to zero.
    153,986Coins
    +11,162 / 57 / -2
    Try allocating '0' for the min value in the Tuning Center for any axis where you want "negative" motion to be cropped.
    153,986Coins
    +11,162 / 57 / -2
    Beat me to it :grin
  11. BlazinH
    16,691Coins
    That's not an easy thing to do :D.
    Also I will be offering new motor controller software soon named Awesom-O that will let you crop positive and negative values individually to whatever you wish by moving sliders which will then show their positions on a graph (similar to SMC3 utilities). It will also feature a whole slew of other improvements over what SMC3 offers like 12bit resolution for starters. More to come.
  12. FredBasset
    461Coins
    Thanks guys, I've looked at this site on and off for years. Really glad I've started to build something and appreciate the help
