Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.3.0.0 pointer update
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,292Coins
    Here is the XML for Fleet Carriers Update - Patch 3
  2. kev b
    kev b Active Member
    Academic Lecturer - Electrical Engineering
    Swindon, UK
    919Coins
    3DOF, Arduino, Motion platform, 6DOF
    Nice - about to test the xml
    UPDATE: all working well again. Thanks again @Wagnard
  3. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    I am a bit lost trying to set up my gamevibe for elite dangerous. I wonder if someone could share there settings?
  4. Mechromancer
    434Coins
    I see that ED is broken again... :(
  5. Mechromancer
    434Coins
    Oh! Wagnard was already on it. Cool!
    I'll report back.
  6. Arianus One
    Arianus One Tony Rom
    empleado
    16Coins
    Hello, good morning friends, does anyone have a simulator 2 dof so show me how the game engine is configured in axis 1 and axis 2? In the last update (update 3 of 07/14/2020) of elite dangerous horizon vr?
    picture show config for srv the ship move whit pitch & roll,
    I change the config every time I change vehicle, is there one that works without having to change it?
    I use google translator i Speak spanish. Greetings and thank you very much
  7. Mechromancer
    434Coins
    New pointers all working for me. No SRV, so i can't test that, but the ship is all working.
    Thanx Wagnard!!
  8. Mechromancer
    434Coins
    Was a patch 4 put out recently?
  9. kev b
    kev b Active Member
    Swindon, UK
    919Coins
    Hey guys,
    todays ED patch (4) has stopped the motion. Hope mr @Wagnard can work his usual magic with the xml. Lets all hope FD have sorted out the bugs this time and don't do anymore patches
  10. Wagnard
    Wagnardsoft
    5,292Coins
    I'm on it.
  11. Wagnard
    Wagnardsoft
    5,292Coins
    Here is the XML for Fleet Carriers Update - Patch 4
  12. kev b
    kev b Active Member
    Swindon, UK
    919Coins
    Hi @Wagnard . patch 4 xml update working fine here (ship and srv). thanks again for sorting it.
  13. Mechromancer
    434Coins
    GAAAAAAAAH!! C'mon FD, get it straight!
    Trying the new xml tonight.
    Thanx Wagnard.
  14. Guyotine
    Guyotine New Member
    - 1Coins
    3DOF, SCN6
    Thanks Wagnard!
  15. Mechromancer
    434Coins
    Everything in the ships working great! No SRV for me though, so can't speak to that.
  16. Wagnard
    Wagnardsoft
    5,292Coins
    You can try the SRV in the training :)
  17. freedom
    freedom New Member
    - 136Coins
    Hi Wagnard,
    i only want to say a BIG THANK YOU to you!!!
    Without you i could not use my Motion Simulator for Elite!
    It is so much more immersive with the Motion Simulator :)
    You are so fast in updating the Plugin, thats awesome!
    So yeah thanks again for evertyhing and stay healthy!
    Best regards
    Pascal
  18. IntrudR
    IntrudR New Member Gold Contributor
    124Coins
    Dear all
    I installed the Elite_Dangerous_Horizons_(XML_edition) via plugin updater and patched the game.
    After that I installed the current EliteDangerous64_Offsets also via the plugin updater.
    As soon as ED is started the GameManager crashes and I receive following error in the event viewer:
    Application: SimTools_GameManager.exe
    Framework Version: v4.0.30319
    Description: The process was terminated due to an unhandled exception.
    Exception Info: System.EntryPointNotFoundException
    at EliteDangerous64_GamePlugin.GamePlugin.GetBaseAddress64(UInt32)
    at EliteDangerous64_GamePlugin.GamePlugin.UpdateGameBase64()
    at System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
    at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
    at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
    at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
    at System.Threading.ThreadHelper.ThreadStart()
    The file GetBaseAddress64.dll exists in C:\Users\fabia\AppData\Local\SimTools\GamePlugins
    Updating simtools to current version did not help.
    Does someone have any idea what I should do?
    Thanks a lot in advance!
  19. Wagnard
    Wagnardsoft
    5,292Coins
    Issue related with your wow64ext.
    The wow64ext must be removed from the Appfolder location(if present), not from the simtool installation directory.
    And the wow64ext should be around 700kb in size in your simtool installation directory .
    If its the small edition(9kb), download simtool from this forum and replace it
  20. kev b
    kev b Active Member
    Swindon, UK
    919Coins
    I've made some significant improvements/enhancements to the rig since 2018. I've just this minute uploaded a latest vid on the 'projects' page. It'll be a feast for the eyes I'm sure (but I am biased lol)
