OpenFFBoard - Controller for custom direct drive wheels
Discussion in 'Direct Drive Wheels' started by Ultrawipf, Mar 15, 2020.
  1. Ultrawipf
    Ultrawipf New Member
    123Coins
    While posting short ideas about this project for a while in a different thread i would like to show the current progress and discuss features and requests in its own thread.
    The announcement video shows the progress i made in the last month, what the basic idea is and what it can already do.
    Obviously its far from finished and requires some setup time but this should improve with time as a GUI is planned and the whole setup procedure will change.
    The basic idea is to have a universal usb interface that can load different main classes for different applications based around HID FFB gamepad functions and CDC serial ports but different usb configurations are possible too.
    This takes away some of the more complicated work of building a custom interface.
    For wheels for example a configuration is provided and constantly improved.
    It will support different sources for buttons, different motor drivers and encoder sources and later hopefully also multi axis setups for flight simulators as well.
    A motor driver specifically for this project was also developed based on the Trinamic TMC4671 which is a brand new chip that supports FOC torque control of DC motors, 2 phase steppers and 3 phase servos.
    If thats not what you need you can write your own motor driver class. Thats also supported.
    Update1:
    GUI was started and servo support implemented and tested with a 130ST-M15015
    Update 2:
    New TMC4671 motor drivers and more pins
    Documentation on hackaday.io
    Code will be updated on github
    • Like x 2
    • Winner x 1
    • Informative x 1
    • Useful x 1
    • Creative x 1
  2. Hoantv
    Hoantv Active Member
    981Coins
    AC motor, Arduino
    Interested project.
    Currently i made ffb firmware for stm32 (ported from arduino leonardo)
  3. Sieben
    Sieben Active Member
    2,241Coins
  4. Gadget999
    12,035Coins
    good work ! have you compared a stepper motor vs a 1kw dc motor ?
    how much does it cost to build a wheel ?
  5. Ultrawipf
    123Coins
    I have not tested a DC motor or 3 phase servo yet myself. A servo would be the preferred option but before i can say that for sure i would need one for testing.
    For the cost i can only comment on my stepper setup.
    I would say a simple wheel setup with stepper motor, driver and power supply can be done for under 300€ but that depends on many factors like the motor, accesories, and mounting hardware. More with a servo, maybe less if you already have a power supply or get the motor shipped cheaper.
    A nema34 stepper with encoder is normally around 100-120€. Servos can be much more. Or you are lucky and find a used one :)
    The Open FFBoard with the TMC motor driver and resistor would probably be somewhere around 100€+ but of course still less than the really high end options and commercial wheels. (~15-20€ controller, ~90€ motor driver + some for resistor and terminals) depending on assembly and parts cost... With higher quantities the cost would go down for the parts.
    Just a rough estimate. It would be really cool to be able to make some kits as i got a lot of questions about that but don't take this as a final answer as there are many fees and factors that could add up.
  6. kiwibrick
    kiwibrick New Member
    12Coins
    hmmm I have a nema23 stepper laying around (well spare for my cnc!), would just need to add an encoder and a driver to be able to maybe try this out with minimal cost to me, only 425ozin steppers but that would still be as strong as my G27!
  7. Gadget999
    12,035Coins
    Another video has been released
    https://m.youtube.com/watch?feature=youtu.be&v=gG_dbnKfH5Q
    A question :
    The mige wheels are sold with a driver, the open ffb does not need a driver and uses mosfets. Does the mige driver convert ac to dc ?
    Is there an advantage / disadvantage using a mige driver
    Great project - what do you use to power your wheels
  8. Ultrawipf
    123Coins
    The motor drivers commonly sold with these servos are not really supported or tested. The TMC driver replaces them and allows a higher resolution and is optimized for this application.
    With some coding you might be able to get the standard drivers to work via UART but i can't promise anything.
    As the power supply i recommend a 48V psu.
  9. Gadget999
    12,035Coins
    is there a target price for the board ?
    could the board be used also to control a motion sim motor ?
    how many amps/volts will the motor drivers take ?
  10. Hikari Voss
    Hikari Voss New Member
    82Coins
    Im interested in building a osw using a mige 130st-m10015 and your open ffboard.
    But the mige motors that I have found on alibaba and aliexpress have 2500ppr encoders, would it be worth upgrading to a biss-c absolute encoder or a 10000ppr encoder?
    If so could you give me a link to buy a 10000ppr/Biss-C encoder because I can't seem to find any for sale. Preferably from the EU or UK but from alibaba or aliexpress would be fine to
    Thanks a bunch.
    Hikari
  11. Ultrawipf
    123Coins
    Sorry for not seeing this earlier.
    Biss-C is nor really supported by project yet because the motor driver only supports SinCos, 3 phase UVW, quadrature incremental and hall sensors.
    For other stuff we would have to stream it through the stm which is not that great but may be possible later.
    Also: Update 2 is out with some info about SinCos. I would use SinCos instead of Biss-C if you have the choice and want to use our driver later once ready.
  12. ThatDbagMike
    ThatDbagMike New Member
    22Coins
    Any updates on this? Recently lost my trusty G27 and now looking into a DIY dd setup. I noticed in the first video you're using a logitech shifter, is use of other logitech items something that would be integrated into the chip?
  13. Faisal Nyan
    Faisal Nyan Member
    Just a Maker
    375Coins
    DC motor
    Go to the video and look in the channel for updates, also, join the discord in the description for more live updates
  14. fzxj520
    fzxj520 Active Member
    1,341Coins
    Someone can disclose more details about openffboard's use of odrive and VESC
  15. fzxj520
    1,341Coins
