Esp32 BLE Wireless wheel
Discussion in 'DIY peripherals' started by Chris_Beeves, Jul 6, 2020.
  1. Chris_Beeves
    2,083Coins
    On my hoverboard wheel I have been trying to make the wheel wireless using an esp32. I now have it working, but something makes it disconnect and connect again every thirty seconds or so. Does anybody else have this problem?
    I’m thinking it could be the receiver, but I’m not sure.
    • Disagree Disagree x 1
  2. Chris_Beeves
    2,083Coins
    @Chris Malcolm , is there a reason you disagree, or just a misclick?
  3. Chris_Beeves
    2,083Coins
    Ok, so it turns out it was my Bluetooth USB dongle that was causing problems. Bought an Asus usb-bt500 and now it works like a charm!
  4. Chris Malcolm
    Chris Malcolm New Member
    291Coins
    Whoops, that was a misclick. :(
  5. Hardsteel73
    Hardsteel73 Hardsteel73
    Self employed
    bergschenhoek
    162Coins
    Is the a public available scheme so I can make that too. And would rev lights be possible like amstudio made?
  6. Chris_Beeves
    2,083Coins
    The code I use doesn’t have leds. I stripped it down to only buttons.
  7. Hardsteel73
    Self employed
    bergschenhoek
    162Coins
    I understand but where can I find the plans for that? And could it be expanded with rev lights and encoders, you think?
  8. Chris_Beeves
    2,083Coins
    My code was built on the same repo this guy built on, but he added encoder support:
    https://github.com/manoukianv/SteeringWheelBluetooth
    I have no idea how to make rev lights. If I would try to do it, I'd look if I could find some arduino solution that could do it today, and try to figure out how to paste it into the code above..
  9. Hardsteel73
    Self employed
    bergschenhoek
    162Coins
    Hey thanks a lot!
  10. mm982566
    mm982566 New Member
    US
    60Coins
    3DOF, 4DOF, 6DOF
    This is kind of interesting, and it's up to 32 buttons now, So I think I should give it a try, thanks
  11. miaziol
    miaziol Member
    Poland
    - 62Coins
    Hello is any wiring plan for it? For wich one pin button and encoders are connected? Sorry for my English.
  12. Chris_Beeves
    2,083Coins
    Hello!
    I believe not. It is quite easy to figure out though if you look into the .ino file.
  13. Pino Pistolidas
    Pino Pistolidas New Member
    Netherlands nijkerk
    184Coins
    I managed to make a button box with up till 19 buttons with the Wemos Lolin32 lite. And this works well.
    I now tried to make one with 3 rotary encoders but this isn't working proparly.
    So let's say button 15 and 16 are on one encoder and they both flash if I turn the encoder clockwise and also if I turn the encoder counter clockwise.
    I see the guy from https://github.com/manoukianv/SteeringWheelBluetooth has rotary encoders working but I can find his sketch.
    So I ended up modifying the "SingleButton" example.
    Does anybody have the right sketch from manoukianv or a suggestion how to connect or program the correct way for the rotary encoders?
    Here is my sketch::blush
    * A simple sketch that maps a single pin on the ESP32 to a single button on the controller
    #include <BleGamepad.h>
    BleGamepad bleGamepad;
    int previousButton1State = HIGH;
    int previousButton2State = HIGH;
    int previousButton3State = HIGH;
    int previousButton4State = HIGH;
    int previousButton5State = HIGH;
    int previousButton6State = HIGH;
    int previousButton7State = HIGH;
    int previousButton8State = HIGH;
    int previousButton9State = HIGH;
    int previousButton10State = HIGH;
    int previousButton11State = HIGH;
    int previousButton12State = HIGH;
    int previousButton13State = HIGH;
    int previousButton14State = HIGH;
    int previousButton15State = HIGH;
    int previousButton16State = HIGH;
    int previousButton17State = HIGH;
    int previousButton18State = HIGH;
    int previousButton19State = HIGH;
    void setup() {
    pinMode(13, INPUT_PULLUP);
    pinMode(15, INPUT_PULLUP);
    pinMode(2, INPUT_PULLUP);
    pinMode(0, INPUT_PULLUP);
    pinMode(4, INPUT_PULLUP);
    pinMode(16, INPUT_PULLUP);
    pinMode(17, INPUT_PULLUP);
    pinMode(5, INPUT_PULLUP);
    pinMode(18, INPUT_PULLUP);
    pinMode(23, INPUT_PULLUP);
    pinMode(19, INPUT_PULLUP);
    pinMode(22, INPUT_PULLUP);
    pinMode(12, INPUT_PULLUP);
    pinMode(14, INPUT_PULLUP);
    pinMode(27, INPUT_PULLUP);
    pinMode(26, INPUT_PULLUP);
    pinMode(25, INPUT_PULLUP);
    pinMode(33, INPUT_PULLUP);
    pinMode(32, INPUT_PULLUP);
    bleGamepad.begin();
    void loop() {
    if(bleGamepad.isConnected())
    { int currentButton1State = digitalRead(13);
    if (currentButton1State != previousButton1State)
    if(currentButton1State == LOW)
    bleGamepad.press(BUTTON_1);
    else
    bleGamepad.release(BUTTON_1);
    previousButton1State = currentButton1State;
    { int currentButton2State = digitalRead(15);
    if (currentButton2State != previousButton2State)
    if(currentButton2State == LOW)
    bleGamepad.press(BUTTON_2);
    else
    bleGamepad.release(BUTTON_2);
    previousButton2State = currentButton2State;
    { int currentButton3State = digitalRead(2);
    if (currentButton3State != previousButton3State)
    if(currentButton3State == LOW)
    bleGamepad.press(BUTTON_3);
    else
    bleGamepad.release(BUTTON_3);
    previousButton3State = currentButton3State;
    { int currentButton4State = digitalRead(0);
    if (currentButton4State != previousButton4State)
    if(currentButton4State == LOW)
    bleGamepad.press(BUTTON_4);
    else
    bleGamepad.release(BUTTON_4);
    previousButton4State = currentButton4State;
    { int currentButton5State = digitalRead(4);
    if (currentButton5State != previousButton5State)
    if(currentButton5State == LOW)
    bleGamepad.press(BUTTON_5);
    else
    bleGamepad.release(BUTTON_5);
    previousButton5State = currentButton5State;
    { int currentButton6State = digitalRead(16);
    if (currentButton6State != previousButton6State)
    if(currentButton6State == LOW)
    bleGamepad.press(BUTTON_6);
    else
    bleGamepad.release(BUTTON_6);
    previousButton6State = currentButton6State;
    { int currentButton7State = digitalRead(17);
    if (currentButton7State != previousButton7State)
    if(currentButton7State == LOW)
    bleGamepad.press(BUTTON_7);
    else
    bleGamepad.release(BUTTON_7);
    previousButton7State = currentButton7State;
    { int currentButton8State = digitalRead(5);
    if (currentButton8State != previousButton8State)
    if(currentButton8State == LOW)
    bleGamepad.press(BUTTON_8);
    else
    bleGamepad.release(BUTTON_8);
    previousButton8State = currentButton8State;
    { int currentButton9State = digitalRead(18);
    if (currentButton9State != previousButton9State)
    if(currentButton9State == LOW)
    bleGamepad.press(BUTTON_9);
    else
    bleGamepad.release(BUTTON_9);
    previousButton9State = currentButton9State;
    { int currentButton10State = digitalRead(23);
    if (currentButton10State != previousButton10State)
    if(currentButton10State == LOW)
    bleGamepad.press(BUTTON_10);
    else
    bleGamepad.release(BUTTON_10);
    previousButton10State = currentButton10State;
    { int currentButton11State = digitalRead(19);
    if (currentButton11State != previousButton11State)
    if(currentButton11State == LOW)
    bleGamepad.press(BUTTON_11);
    else
    bleGamepad.release(BUTTON_11);
    previousButton11State = currentButton11State;
    { int currentButton12State = digitalRead(22);
    if (currentButton12State != previousButton12State)
    if(currentButton12State == LOW)
    bleGamepad.press(BUTTON_12);
    else
    bleGamepad.release(BUTTON_12);
    previousButton12State = currentButton12State;
    { int currentButton13State = digitalRead(12);
    if (currentButton13State != previousButton13State)
    if(currentButton13State == LOW)
    bleGamepad.press(BUTTON_13);
    else
    bleGamepad.release(BUTTON_13);
    previousButton13State = currentButton13State;
    { int currentButton14State = digitalRead(14);
    if (currentButton14State != previousButton14State)
    if(currentButton14State == LOW)
    bleGamepad.press(BUTTON_14);
    else
    bleGamepad.release(BUTTON_14);
    previousButton14State = currentButton14State;
    { int currentButton15State = digitalRead(27);
    if (currentButton15State != previousButton15State)
    if(currentButton15State == LOW)
    bleGamepad.press(BUTTON_15);
    else
    bleGamepad.release(BUTTON_15);
    previousButton15State = currentButton15State;
    { int currentButton16State = digitalRead(26);
    if (currentButton16State != previousButton16State)
    if(currentButton16State == LOW)
    bleGamepad.press(BUTTON_16);
    else
    bleGamepad.release(BUTTON_16);
    previousButton16State = currentButton16State;
    { int currentButton17State = digitalRead(25);
    if (currentButton17State != previousButton17State)
    if(currentButton17State == LOW)
    bleGamepad.press(BUTTON_17);
    else
    bleGamepad.release(BUTTON_17);
    previousButton17State = currentButton17State;
    { int currentButton18State = digitalRead(33);
    if (currentButton18State != previousButton18State)
    if(currentButton18State == LOW)
    bleGamepad.press(BUTTON_18);
    else
    bleGamepad.release(BUTTON_18);
    previousButton18State = currentButton18State;
    { int currentButton19State = digitalRead(32);
    if (currentButton19State != previousButton19State)
    if(currentButton19State == LOW)
    bleGamepad.press(BUTTON_19);
    else
    bleGamepad.release(BUTTON_19);
    previousButton19State = currentButton19State;
  14. Chris_Beeves
    2,083Coins
  15. Pino Pistolidas
    Netherlands nijkerk
    184Coins
    That sketch looks much better indeed, but I'm missing some voodoo.
    I get an error message trying to upload this sketch to my lolin32 lite.
    Do I need to install some libraries first?
  16. Chris_Beeves
    2,083Coins
    Are you using platformIO? Did you download the whole code?
    From what I can see by a glance, these are the includes;
    Code:
    #include <Arduino.h>
    #include "button.h"
    #include "battery.h"
    #include "encoder.h"
  17. Pino Pistolidas
    Netherlands nijkerk
    184Coins
    :blush Sorry I'm a noob, how do I use the platformIO?
  18. Chris_Beeves
    2,083Coins
    It has been a long time since I tried all this. I made my code in ArduinoIDE and lost touch with PlatformIO.
    You need to install Visual Studio CODE and PlatformIO, then download the github repo and run it in PlatformIO. As I recall it was quite self explanatory when it all was installed.
    Maybe you can find something here;
  19. Pino Pistolidas
    Netherlands nijkerk
    184Coins
    I manged to get this working thanks for your help, but the encoders are chnaging the X and Y axis. Do you have any idea how to change this to buttons?
    Also there are only 14 buttons I would like to have 21 (including 3 encoders). I wasn't able to change this either.
    I also am a bit more familair with ArduinoIDE, do you maybe have a skecth with Buttons en Encoders?
  20. Chris_Beeves
    2,083Coins
    Sounds strange with the x y axes.
    I haven’t used this code myself, I only needed buttons.
    Nope, no code other than buttons.
