value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. Dronneau.Y
    Dronneau.Y Member Gold Contributor
    france
    95Coins
    Bonjour,
    Aprés avoir telecharger la version demo 2.5.7.1 64 bits sur steam, et installé le plugin 2.01.1.17 puis activé la telemetrie sur steam, je n'obtient aucuns mouvement, avez vous une piste?
    cordialement
  2. value1
    14,993Coins
    NLR does not output telemetry in the demo version.
  3. Dronneau.Y
    france
    95Coins
    Ok, merci de la réponse rapide, il ne me reste plus qu'a envisager l'achat!!
    151,461Coins
    +11,038 / 56 / -2
  5. hannibal
    hannibal Active Member
    4,491Coins
    axis behavior is weird in this game...
    anyone 6dof would share game engine axis settings?
    should yaw be yaw, or should yaw be extra3?
    151,461Coins
    +11,038 / 56 / -2
    Yaw is rotation around a central point and while it is supported in the plugin I can't image a rollercoaster that spins around a central point (tight turns/short wheelbase single carriage maybe?), so have never used it. Extra 1 is often used for traction loss, I can't see that as supported in the plugin summary and again can't imagine a rollercoaster that has traction loss type motion.
  7. value1
    14,993Coins
    Indeed, the angles of the NLS plugin are crap in certain circumstances. This has to do with the math for the angle calculation.
    I wasn't able to fix it and the angles are therefore sometimes completely wrong upload_2019-12-15_19-40-51.png
  8. hannibal
    4,491Coins
    no, this is better than nothing.
    most appreciate that this is available to mess around with and the effort that went along with it.
    have to say thank you!
  9. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    Oculus home version and Oculus Quest version works with the --telemetry option?
    Is there any other option?
    In the Steam version it works perfectly.
    Tank you.
  10. Metaverum
    Metaverum Member Gold Contributor
    146Coins
    2DOF, 3DOF
    Does this work with NoLimits 2 professional license?
  11. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    YES
  12. Moe Colontonio
    Moe Colontonio Member Gold Contributor
    New Jersey USA
    788Coins
    Working great for me on my 5dof. Is there a way to get my bass shakers to work with NL2?
  13. noorbeast
    151,461Coins
    +11,038 / 56 / -2
  14. Moe Colontonio
    New Jersey USA
    788Coins
    I installed the SimVibe plugin, and I setup the sound card. When I test the transducers, they work, but I get no vibration in game. Not really sure how to troubleshoot this. I did reinstall the plugin and unpatch/patch.
  15. Moe Colontonio
    New Jersey USA
    788Coins
    Disregard, I did not select "Enable Vibe". It's working now!
  16. dontcarefilmer
    dontcarefilmer Member
    Industrial Electrician
    West Sydney, Australia
    367Coins
    I may have a solution for this problem, but I think I'll need your help to build it. I too found the angles calculated with the telemetry to be off when reaching full inversion. So to find out why, I expanded an application I'm working on to also capture the NL2 telemetry and graph the results (using the example maths from the install folder). Then I tried a whole bunch of other configurations and calculations and compared them to the NL calcs. It finally worked (I think).
    https://drive.google.com/file/d/1eQF4XCXG6avXmQVe0LNWW-42gwTQ59Vd/view?usp=sharing
    The graph in the link above was captured whilst on the double loop double corkscrew track. Light green and red are the original NL calculations, dark green and red are my new ones (using the same quaternion inputs qw, qx, qy, qz). You can see the first pair of loops where the pitch angle goes from 180° to -180° twice, plus the corkscrew afterwards. The time axis is a history kind of line, not a timestamp from starting point, the graph updates from the right and moves old data points to the left.
    What I can't do though is write a plugin to test this out...
    I can pass on the calculations for someone else to make a plugin, or I could alter the source plugin if the author felt comfortable sharing it. Whatever works for you guys, what do you think?
  17. Moe Colontonio
    New Jersey USA
    788Coins
    When you guys setup simtools for motion on this, are you banking the rig into the turn, or away from the turn? Most of the rollercoasters have banked turns, so I'd think into the turn would be the better option?
  18. paulopsx2
    brasil
    647Coins
    well, i think this is only a plugin. old plugin. None of us have a perfect maths or experience on roller coasters.
    in fact, dof simulators dont have 360 angles and turns. so, plugin its made for fun and in some cases, not for real.
  19. MarkusB
    4,214Coins
    In a real rollercoaster the car is banking into the turn, but at the same time your body is pressed outwards.
    In a usual 2 DOF simulator you only have the roll axis for simulating roll and sway. When focusing on roll, you would bank into the turn, and when focusing on sway, it would be away from the turn. When configuring roll AND sway onto the roll axis, you would have two competing movements that would compensate esch other.
    About your question: I agree with you that banking into the turn feels more natural.
    Edit: I just sae that your rig includes a g-seat. That means you can bank into the turn for supporting the roll mevement and configure the g-seat paddles for the sway force by applying pressure with the outer paddle.
  20. Moe Colontonio
    New Jersey USA
    788Coins
    Man I wish, my G-Seat is running on SimCommander so I'm stuck using the plugins they have, which are very limited. Can't figure out how to get it running with SimTools.
