$450 Mige Direct Drive Wheel using MMOS and AASD
Discussion in 'DIY peripherals' started by Peacemaker105, May 6, 2020.
  1. sedesa tatasa
    sedesa tatasa Member
    503Coins
    50v is enough for full torque at low speed.
    But actually the reaction of a big motor is bad, so the reaction must be enhanced by PID control.
    Simply put,extra voltage is applied to enhance the reaction when increasing the torque.
    Conventional direct drive wheels are 50v.
    200v industrial driver have more additional voltage.
    I am interested in how this affects performance.
  2. vicborder
    vicborder Vicborder
    - 529Coins
    hi, I had an M15015 engine, I got a problem with the engine vibrations when I put the STM32 to 16.8khz, when I put it at 4 khz, the vibrations decrease, but the engine screaming, someone would know to tell me where this problem, thank you very much
  3. sedesa tatasa
    503Coins
    16.8khz if you don't use dac.
    Try lowering pn190.
  4. vicborder
    vicborder Vicborder
    - 529Coins
    thanks for your answer, pn190. I've got it tight. I think if I lower it or raise it right. It starts to turn left, I got it to -90, if I can turn up video
  5. DJ_BLAZKOWICZ
    DJ_BLAZKOWICZ New Member
    IT TECH
    Scotland
    266Coins
    it's normal that you hear more noise at 4khz.
    i get the same harmonics on 4khz with my motor. you should use 16khz + pn190 between -100/-80 if you don't have a DAC board.
  6. vicborder
    vicborder Vicborder
    - 529Coins
    the video is with dac pn190 -90 at 16khz, I don't understand how the engine vibrates so much
  7. DJ_BLAZKOWICZ
    IT TECH
    Scotland
    266Coins
    probably due to the different inductance this motor has. it has much higher inductance than 130st-m10010 so it will behave differently on same pwm frequency. pn190 won't do anything about the noise it just helps getting rid of the left-right wiggle when the motor is "idle".
  8. vicborder
    vicborder Vicborder
    - 529Coins
    i have it set up according to the engine manual with PN001 to 24, would you have to change?
  9. sedesa tatasa
    503Coins
    Use DAC or cr low-pass filter
    You need to smooth pwm.
    If not, increase Pn188.
  10. vicborder
    vicborder Vicborder
    - 529Coins
    forgive my ignorance, how does the cr low pass filter fit?:(o_O
  11. sedesa tatasa
    503Coins
  12. vicborder
    vicborder Vicborder
    - 529Coins
    thanks when I have some material I'll try
  13. Peacemaker105
    Perth, Aus
    2,009Coins
    what Pn188 have you got it set to? but yeah try that filter also :)
  14. vicborder
    vicborder Vicborder
    - 529Coins
    Pn188 to 159
  15. sedesa tatasa
    503Coins
    Does the vibration you mentioned at first mean this noise?
    Doesn't it change even if Pn188 is increased?
    Is there noise in the jog test?
  16. vicborder
    vicborder Vicborder
    - 529Coins
    there noise in the jog test perfect, with parameter No 188 I don't notice change, this afternoon I'm going to try changing the cable to stm32 i play a little with the parameters
  17. sedesa tatasa
    503Coins
    @vicborder
    Do a jog test without connecting stm32.
    Is there noise?
  18. vicborder
    vicborder Vicborder
    - 529Coins
    i don't know if it's a problem, but just connecting CN2 pin 9,6,10,13,20,18,15, with the pn190 parameter, the engine starts to turn right just by when I put it to -90
  19. vicborder
    vicborder Vicborder
    - 529Coins
    i mean, that empowering just the -E-Stop, engine turns only to the right and to stop the movement I have to put PN190 to -90, is that normal? thank you
  20. Kyle Francis
    Kyle Francis New Member
    45Coins
    slightly off topic, but still to do with the setup. I know people use the g25/27 pedals/shifter to plugin to the board, but has anyone plugged in diy or other brand of pedals? Obviously the pedals are just 3 pots and this should be east, but i know the shifter uses two pots to determine what gear and a switch for reverse gear selection.
