Research instruction of how to build a simulator
Discussion in 'DIY Motion Simulator Projects' started by gpau, Aug 4, 2020.
  1. gpau
    gpau Member
    550Coins
    I would like to build a 6dof driving simulator, there is a list of the necessary material, wiring diagrams and some projects. To tell the truth years ago I had found some material to be able to build it, but as I no longer followed the forum I lost everything and would like to take it back, is there someone who can kindly give me some indications?
    Thank you
  2. Zed
    USA
    5,847Coins
    Most of the designs here are done by hobbyists and end users so documentation in maybe most cases is just the high points or trouble spots. Good, but not really step by step how-to guides. There are some who document their builds really well, though, and include parts lists, sources, and even CAD drawings.
    What you might want to do is just start reading through the various 6dof build threads and see which appeal to you and your build skills. There are a number of different kinds of actuator designs and all have pros and cons. These things seem to never be totally done and most builders are still active or lurk. You can always ask them questions if something isn’t clear.
    Good luck!
  3. gpau
    gpau Member
    550Coins
    I should take pictures of what I already have, maybe I can get more help. I had already welded the two hexagonal bases one large and one smaller, I already have the six motors and power supplies
  4. Zed
    USA
    5,847Coins
    All of that would be good information for others to help you and saves a lot of time. If you already have that stuff, then are you looking for a specific simulator here? If so, if you give as much as you remember, or try some searches, you would probably find it.
  5. gpau
    gpau Member
    550Coins
    What I have is this
