Question Flight Simulator Pre Sets
Discussion in 'Game Engine axes presets' started by terry wells, Aug 22, 2020.
  1. terry wells
    terry wells Active Member
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    I am far into the process of converting my motion flight simulator from 2DOF to 3DOF and I was looking for a good starting point to set my Axis Assignments for this setup. I defiantly need Pitch, Roll and Heave.
    Thank You
    hpwells
    153,986Coins
    +11,162 / 57 / -2
  3. terry wells
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    OK, however I think that I will stick with Sims Tools. Should I program my axis assignment to have a total of 100 to 120%? (like roll=60, pitch=40, heave= 20) ? And is this done on all three axis?
    153,986Coins
    +11,162 / 57 / -2
    As per the motion profile refinement link you can allocate around 80% for roll and 80% for pitch, which will give a total allocation of at least 160+%, depending on what else you add, like 20% for heave, because for general aviation you are unlikely to use max allocation for roll and pitch at the same time.
