Buckle up for Project Cars 3 - Summer 2020
Discussion in 'Project Cars' started by noorbeast, Jun 4, 2020.
  1. noorbeast
    153,039Coins
    +11,116 / 56 / -2
    Project Cars 3 is scheduled for release summer 2020.
  2. lysa elec
    lysa elec LYSA ELEC
    - 2Coins
    when did project cars 3 come in thes shops ?
    153,039Coins
    +11,116 / 56 / -2
    As per the title at the moment Project Cars 3 is expected to be released some time in the Summer 2020.
  4. lysa elec
    lysa elec LYSA ELEC
    - 2Coins
    i think that il is for the 28 aout 2020
  5. Lgars39
    Lgars39 Member
    Jura
    208Coins
    pre-order possible
  6. Zed
    USA
    5,845Coins
    Unfortunately it’s looking like the new brand owners have mainstreamed it. It’s supposedly not the same ProjectCars used to be.
    Anyone looking to get it shouldn’t just go on the franchise name.
  7. RobertH
    RobertH Member Gold Contributor
    The Netherlands
    1Coins
    2DOF, SCN5
    Does anyone already have a plugin for PC3?
    153,039Coins
    +11,116 / 56 / -2
    Not yet.
    • Optimistic Optimistic x 1
  9. pmvcda
    15,660Coins
    Telemetry is the same as pcars2
    Being part of wmd1 and 2, I'm really sad the way they took pcars3...
  10. Michael Maggio
    Michael Maggio New Member Gold Contributor
    usa
    10Coins
    So i'm unsure how i get it to work? Help!
  11. pmvcda
    15,660Coins
    To work with SimTools, maybe rename the exe to PCARS2
    And go to options and select telemetry for PCARS2 in the game menus
    SETUP->SYSTEM
    (here in Portuguese)
  12. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    The telemetry is indeed the same as pcars2. As stated above, it's either a case of adding the new .exe name to the existing pcars2 plugin, or manually renaming the pcars3 exe to pcars2, then running simtools with the old plugin.
    Not sure what the new telemetry brings over the old one to justify a whole new plugin, but I guess there is a reason it's changed.
  13. Newgun
    Newgun Member Gold Contributor
    77Coins
    AC motor, 4DOF
    Hello @Sarge, how would one add the new .exe name to the existing pcars2 plugin?
    I'm downloading the game now and hope to try it with motion if possible. Thanks.
  14. Sarge
    - 181Coins
    Inside the plugins, there is a line where the process name(s) are entered. It would need the authors with the source file to recompile it, but as an example, this is what it would look like inside the plugin;
    I wont have the game until tomorrow, so I'm just guessing the process name.
    For now, your simple option is to just change the name of the .exe to match a name the plugin will recognise (you can choose any of those in process name string from the picture above). Remember to set the telemetry to Project Cars 2 within the options in Project Cars 3. That should get you going for now until the guys here have the time to release a proper plugin.
    Cheers.
  15. Newgun
    77Coins
    AC motor, 4DOF
    Awesome. It looks like adding the .exec would require edits that can only be made by the original author, or it's definitely something more advanced than just simply inputing text in the string of the plugin. I'll try renaming the .exe for now. Thanks for detailed explanation Sarge!
  16. Megahowler
    Megahowler New Member Gold Contributor
    - 27Coins
    4DOF
    I can confirm.. Renaming the EXE works
  17. Michael Maggio
    usa
    10Coins
    when i input it into the updater, it still refers to the plugin as pc2 even after renaming it
  18. noorbeast
    153,039Coins
    +11,116 / 56 / -2
    You should not rename the plugin, but rather the game EXE.
  19. Megahowler
    - 27Coins
    4DOF
    Yes to be super clear...
    I simply renamed the Project Cars 3 exe to Pcars2.exe
    motion on my SFX-100 with the thanos controller works perfectly
  20. Sarge
    - 181Coins
    I've bought the game today and looked into another solution. Steam simply would not allow me to run a renamed .exe for some odd reason. Every time I run the renamed .exe, Steam would automatically replace the renamed .exe to the original pcars3.exe file.
    However, below is the solution to run motion without renaming the pCARS3.exe file;
    Download the manual Project CARS2 plugin found here;
    https://www.xsimulator.net/communit...-uses-new-udp-format-manual-plugin-start.197/ (Credit to @vthinsel)
    If you haven't already, install the above plugin via plugin updater, patch the game and click the manual start button. Doing this negates the need to rename the .exe file. Just manual start the above plugin and run the game.
    I have tested this method, and found it to be fully working.
    Happy driving.
