The night I realised I need a kill switch
Discussion in 'Off Topic - All other stuff here' started by Zippo246, Aug 31, 2020.
  1. Zippo246
    Zippo246 Member
    Sydney, Australia
    158Coins
    3DOF, Motion platform
    I'm still very new to motion, and was foolishly impatient. Just finished building my rig, fired up DCS using FlyPT's amazing software, and airstarted in the L39. Decided to try out ALT-S to test output start/stop hotkey. All I did was shutdown engine in flight.
    Okay, opportunity to try out a deadstick landing....not on a runway....without ever tuning the software. This thing was throwing me around, making a racket, my wife opened the door to see what was going on. I asked her to turn of power to servos. 10 seconds seemed like 2 minutes. Wife asked me to give her a heads up next time I want to do that - I advised between gasps that if I knew this was going to happen, I wouldn't have let it happen.
    The keyboard stayed on the tray because I was unsuccessfully punching ALT-S,
    which was doing nothing (it just knows....) but there were keyboard keys lying all over the floor.
    My warthog throttle jumped of its tray (now zip tied down as an interim) and crashed onto the floor, its own weight shearing its USB cable.
    I have ordered parts for a kill switch and will get that happening this week. I was successful in resoldering wires to Warthog PCB, and have tested that it is working again as advertised.
    This was a bit of a scare for me, I'm still a bit gun shy, and won't test more until I get the e-stop connected but looking forward to learning more as I continue.
    Cheers, John
    • Like Like x 5
    153,920Coins
    +11,156 / 57 / -2
    A hard way to learn a valuable lesson ;)
    A rig should be thoroughly tested and dialed in before being cut loose.
  3. Thanos
    Electronics Engineer
    2,907Coins
    Yeah, e-stop switch is necessary to be sure that the servos won't move at times, if simtools is still connected. But you could use of a force offline switch as well, that prevents motion without shutting down the servos. Not sure what controller you are using but for the AMC-AASD15A, this is available:
    https://www.tindie.com/products/bajer/emergency-stop-switch-with-led-indicators/
    Thanos
  4. pmvcda
    15,702Coins
    Always, always and always test outside of the rig before going in.
    Even outside I got my scary moments, if not in risk of physical damage, it's the money damage.
    In my rig I have two emergency buttons:
    One in the rig and one outside on the electronics. We never know!
    And using keyboard or mouse in those situations is near impossible, please assign a joystick button for that, you can do it in Mover.
    • Agree Agree x 3
  5. Zippo246
    Zippo246 Member
    Sydney, Australia
    158Coins
    Hi Thanos,
    I'm using your controller, and have ordered parts to do just that, your instructions in your manual are really good, thanks.
    Bed time now. I flew the L39 again using Simtools and haven't scared myself, there is a bit to get my head around.
  6. Lesmore222
    Lesmore222 Member
    205Coins
    If you hit the kill switch on your wheel will that accomplish the same thing?
  7. caddyboy0103
    caddyboy0103 New Member Gold Contributor
    11Coins
    Hopefully everything is ok... it could have been worse
  8. Zippo246
    Zippo246 Member
    Sydney, Australia
    158Coins
    Hi Caddy, yep, it could have been much worse. All is back to normal in the world (this little sim space at least) and I'm a bit wiser.
  9. andres50
    andres50 simulador de vuelo (flight simulator 2020)
    mecanico
    pamplona
    - 254Coins
    [QUOTE = "Zippo246, post: 204312, member: 27933"] I am still very new to the movement and was foolishly impatient. I just finished building my rig, powered up DCS using FlyPT's amazing software, and booted up on the L39. Decided to try ALT-S to test the exit start / stop hotkey. All I did was turn off the engine in flight.
    Okay, chance to test a landing in neutral ... not on a runway ... without even adjusting the software. This thing was spinning me around, making a fuss, my wife opened the door to see what was going on. I asked him to change the power to the servos. 10 seconds seemed like 2 minutes. My wife asked me to let her know the next time she wanted to do that; I warned her between gasps that if she had known this was going to happen, she would not have let him.
    The keyboard stayed on the tray because I couldn't press ALT-S,
    he wasn't doing anything (he just knows ...) but there were keyboard keys all over the floor.
    My boar throttle jumped out of its tray (now zipped up like an interim) and crashed to the ground, its own weight severing the USB cable.
    I have ordered parts for a kill switch and will get it this week. I had success re-soldering wires to the Warthog PCB, and have tested that it works again as advertised.
    This was a bit scary for me, I'm still a bit shy and won't try any more until I hit the emergency stop, but I hope to learn more as I continue.
    Cheers John
    76314
  10. stanley johnson
    stanley johnson Active Member
    Diesel tech
    Nashville
    82Coins
    I’m sorry this happed and I will definitely add a kill switch to mine. But I gotta tell you, I have not laughed this hard in a while. Please be safe
  11. Yousef101
    Yousef101 New Member
    101Coins
    yah always have a kill switch or other safety options otherwise its very dangerous and as others said try to test it while u outside the rig
  12. Ben Clements
    Ben Clements New Member
    - 30Coins
    Glad you're ok, these things are powerful, I very nearly lost a finger to mine... Now I will ALWAYS recommend a kill switch as a priority!
  13. Zippo246
    Zippo246 Member
    Sydney, Australia
    158Coins
    Hmmm, I often recall that evening with a wry smile....
  14. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    Hello, this post is relevant for me, because I assembled a layout and when the game starts, it makes a sharp jump on all axes and then everything works perfectly, but if there is nothing to turn it off in case of an accident, it may end badly
