Question Star Wars: Squadrons is Coming with VR Support! Motion Possible??
Discussion in 'Other Flight Simulation Games' started by Michael Jeffries, Jun 16, 2020.
  1. Michael Jeffries
    Michael Jeffries Member Gold Contributor
    485Coins
    Motion platform, 4DOF
    I have already got my pre-order in to EA's first VR title and it's a Star Wars Flight title with HOTAS support!
    Do you think we'll see motion supported???
    152,676Coins
    +11,089 / 56 / -2
    Generally speaking a game has to be released and stable to make supporting a plugin easier. Do you know if Star Wars: Squadrons has telemetry API?
  3. Michael Jeffries
    485Coins
    i guess we’ll have to wait and find out. Its a first for EA so it might just have a telemetry api also.
  4. Mechromancer
    434Coins
    Was wondering about this also.
    Let's hope one of our braniac members comes up with a plugin...:::looks a @Wagnard ::: :p
  5. BlazinH
    16,671Coins
    We can hope but usually this type of game is only accessible using memory hooks.
  6. ART FLY
    ART FLY Gettin' High on DIY :) Gold Contributor
    Bavarian State Theater, Decoration Stock Manager
    BAVARiA
    421Coins
    Preordered @ Steam.
    Always look on the bright side - stay safe mates,
    Yours ARTi
  7. Wanegain
    Wanegain Active Member
    Bruxelles
    2,011Coins
  8. kevinmarz
    kevinmarz Member
    346Coins
    Should I be buying this game from Steam,made this mistake with other games in the past..cause it needed a Steam version to play it..like Gta 5 had the epic version...and had to re-buy it
    152,676Coins
    +11,089 / 56 / -2
    Generally most plugins if and when they are developed are against Steam versions, though there are some exceptions. At the moment unless a telemetry API is released, or some brave soul wants to create and maintain a hook based plugin them your best bet will be the existing generic Joystick plugin, in which case it should not matter where the game was purchased from: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
  10. rafinnovation
    rafinnovation New Member
    Suisse
    44Coins
    Joyrider
    New
    Hello, I just bought the Star Wars Squadrons game. I installed the joystick plug-in, but I cannot get it to work. I have 52 hotas but I can't find it in the USB list which goes from 0 to 15. I have a Windows driver but, when I activate it, my simulation moves in all directions and I can't do anything with ... Can you help me please.
  11. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Hey guys. Is it possible in simtools to simply couple movement to the Joystick? In such a way that you can only make slight tilting movements? I prefer that to no movement at all.
  12. kevinmarz
    kevinmarz Member
    346Coins
    NO!!not the joystick plugin..oh god No!! lol..doesn't feel the same as the game plugin works..but thanks for the reply
  13. Newgun
    Newgun Member Gold Contributor
    77Coins
    AC motor, 4DOF
    I tested the JoyStick plugin and it works rather well for pitch, roll and yaw (to a certain extent depending on your traction loss axis). You do have to see what movements your joystick is doing in the tuning menu, and thereafter assign your axis to what you want it to do in relations to the joystick movements. I'm using a t.16000m joystick and my actual pitch and roll movement on the flight stick was reading as sway and surge in the tuning menu.
    @rafinnovation the joystick plugin will only work with one joystick. So if you have other controllers plugged in, I believe you want to make sure that the joystick you're using is set to preferred in the properties menu. I had issues doing this with mine so I had to unplug and plug the joystick usb through trial and error, so that the joystick application read my flight stick. I also noticed that selecting the different joysticks in the "Select Your Joystick" window didn't make a difference. Hope this helps.
  14. Bastiuscha
    750Coins
  15. SilentChill
    20,596Coins
    No chance of any memhook plugin, the game has EasyAntiCheat so we cant read any memory loactions or basically do anything with the process file :( damn !
    • Informative Informative x 3
  16. KydDynoMyte
    KydDynoMyte Fool's Gold Contributor
    RTP, NC
    50Coins
    Should be able to disable EasyAntiCheat and at least have a memhook plugin for single player offline play.
  17. SilentChill
    20,596Coins
    Nope it won't load unless anticheat is on :(
  18. pmvcda
    15,571Coins
    Good candidate for joystick plugin... :(
  19. SilentChill
    20,596Coins
    :grin:grin:grin:grin
  20. KydDynoMyte
    RTP, NC
    50Coins
    I just played a quick practice session on the monitor with EAC uninstalled. Seems to work fine offline. It didn't fix my problems with it crashing in VR like I hoped it would. I still need to work on that.
