Looking for worm gear motors for 6DOF
Discussion in 'Marketspace - Marktplatz' started by Rifly, Sep 1, 2020.
Tags:
  1. Rifly
    Rifly Member
    freelance photographer
    Latvia
    232Coins
    150,025Coins
    +10,993 / 54 / -2
    Just curious, have you considered servo motors and @Thanos driver?
  3. Thanos
    Electronics Engineer
    2,798Coins
  4. Rifly
    Rifly Member
    Latvia
    232Coins
    @noorbeast @Thanos
    Got info back on my inquiry for worm motors mentioned above - 180 usd motor +160 shipping, I guess if I get them all it will be equal to servo drives with gearboxes, but I will have to get controllers and supply separately right?
    I will have to get my calc out and start thinking what costs what. Thanks for pointing to servo direction.
    I know how to use search but by any chance, have a build thread you would recoment as simple and budget friendly?
  5. Thanos
    2,798Coins
    Correct. For the DC motors you will need to also buy drivers (Sabetooth or MM) and power supplies with balancing batteries for each motor etc...
    The AC servomotors come with matching servo drive, that it just needs to be directly wired to 110v or 220v for power. Simple and neat.
    https://www.aliexpress.com/item/32973113245.html
    See such servomotor attached on a small linear actuator. The servo drive then attaches to one of the db25 ports on my controller via a simple straight DB25 cable, no need to custom wire anything!
    There are examples of really small footprint 6dof platforms here in xsimulator forum. But check out the videos of this guy here that explains everything on how you can build such platform with servos:
    https://www.youtube.com/channel/UCxCueff3Tde6i2naPJmcXWg
    And if you don't want to use hard stop for calibration of the rotary actuators, you can even attach inexpensive contactless induction sensors... see this:
    Thanos
  6. Thanos
    2,798Coins
    Besides. You don't want to spend all this money on DC motors to get this motion ( not even synchronized)
  7. Rifly
    Rifly Member
    Latvia
    232Coins
    @Thanos
    Im not sure if I can be pushy enough to ask more info about lifting capability of this combo
    lets say I chose recomended motor with 1:50 gearbox
    My weight is 95-100kg, and current 2dof top platform weight about 60kg with wheel and seat.
    P.s since this is becoming build thread I will be making new purpouse one a bit shorter.
  8. Thanos
    2,798Coins
    Using 2.4Nm servomotor and 50:1 gearbox, according to my calculations you should be able to handle about 70kg on 150mm long arm (which the rods of your 6dof attach on).
    That is 70kg per motor, total 420kg if all actuators work synchronized to lift the load...
  9. Rodeo5150
    Antioch, CA, United States
    1,251Coins
    Arduino, 6DOF
    I wanted to use your thanos card but $400 for one card is just not gonna happen. The whole reason for diy is because were not made of money. But awsome work though. I wish I could afford one
  10. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    Yes I would need some direction to go that route in order just to know to let some Direction on how they're built also I can't afford no $500 for Thanos card it's just that can't happen I can't spend that kind of money that I dont have on one pcb
