Skuldi´s 2DOF seat mover project
Discussion in 'DIY Motion Simulator Projects' started by Skuldi, Sep 1, 2020.
  1. Skuldi
    Skuldi Member Gold Contributor
    Germany NRW
    265Coins
    OK, time for my own little thread.
    As i mentioned, @Bastiuscha helps me a lot with my build so everything went really smooth. At least until now! :D
    My Parts:
    Arduino Uno ( changed the clone with a original R3)
    12v 100a server power supply (HP DPS-1200FB)
    Link: HP DPS
    2 DC brushed motors (12v 370w 50:1)
    Link: 90ZYT
    2 contactless potentionmeters (RTP180LVEAA)
    Link:RTP180LVEAA
    for the potentiometers I needed two connectors
    Link: 282087-1
    and pins
    Link: 282110-1
    Sabertooth Dual 60A:
    Link: Sabertooth
    Everything connectet together:
    bass shaker
    Link: Sinuslive
    audio amplifier
    Link: no name
    as a seat i got a Gtultimate V2 + Flight Pack
    Link: GTultimate V2
    as a joint for the seat I used an old nissan 200SX S13 propeller shaft (Kardanwelle)
  2. Skuldi
    Germany NRW
    265Coins
    For some first testing i bolted everything on a wooden plate.
    first the seat to find balance
    after that I added the bass shaker and the ball joints
    I mounted the motors a little bit higher so the lever can spin freely. I tried to get the magnets on the shaft by using wood but that din´t work out well an will lead to my profile avatar later on.
    Everything ready for smc utils! :D
    After everything worked well in smc, i booted up Sim Tools 2.4.1 for the first time and set up the software with help from bastiuscha.
    Of course I clicked on output testing without thinking. Motor one immediately lost his shit and started moving at high speed. The movement was so hard that the magnet fell off and I had to cut power to stop the motor.
    I rolled back to simtools 2.4.0 and found a better solution for my magnets.
    Everything works now, time for life for speed!
    I crasht in a wall and this time, motor two started spinning.
    With my weight on the seat, the motors wiggled so much, that the sensor lost the magnet for a short moment which leaded to the motor spinning around.
    153,986Coins
    +11,162 / 57 / -2
  4. Skuldi
    Germany NRW
    265Coins
    Got some work done.
    first of all, this little guy who tried to escape last week:
    I´m relay glad that I noticed before he fell off!
    Build new mounts for my motors:
    Made my lever a little shorter:
    it got pretty late yesterday and I still have to connect everything for the next test.
    also looked for a kill switch and i will go with a car battery switch like this.
    But for time being my dad will akt as a kill switch.:D
  5. Skuldi
    Germany NRW
    265Coins
    today i made everything ready for the next LFS test.
    sadly i have to wait till next weekend for that.
  6. Skuldi
    Germany NRW
    265Coins
    I tested my Prototyp today.
    Drove for around 2 hours without any problems!:)
  7. Skuldi
    Germany NRW
    265Coins
    My solution for the server power supply:
    i will add some electrical tape and hope for the best ^^
  8. Skuldi
    Germany NRW
    265Coins
    New base plate!
    Its a 1.60m * 0.80m*0.02m screen printing plate.
    I used this little guys here to bolt the motors and the seat down
    cable management for wind sim
    some sweet neoprene
    and needle felt carpet for sound reduction.
    I hope i can drive with that without getting trouble with my neighbors.:D
  9. Skuldi
    Germany NRW
    265Coins
    another weekend full of work!
    I added a power cap to support the power supply
    and a battery switch, so i can turn the motors off, in case something go's wrong
    A plug and arduino+ motorshield for windsim
    final mounts for the sensors and cable management for the wires
    my rig finally out of the cave! :D
    Vid form the test on sunday:
  10. Skuldi
    Germany NRW
    265Coins
    last weekend i added springs and i cant believe how much smoother the movement is now!
    and found a way to mount windsim on my wheel stand.
  11. Skuldi
    Germany NRW
    265Coins
    Build a small removable box around the electroniks.
    well, guess i´m done for now :)
    Playtimes before motionseat :
    Assetto Corsa: 90,2
    Project Cars 2: 27,3
    Dirt Rally: 15,8
    Dirt Rally 2.0: 11,9
    Automobilistan 2: 1
    DCS: 327,6
    Elite Dangerous: 307,3
    let´s see how much the numbers will rising before that thing breaks for the first time ^^
  12. Skuldi
    Germany NRW
    265Coins
    Had some issues with the motors. They stand still after hart movements. Changing the psu and the power cap did not help. Turns out the cables were the problem. Changed the old ones with copper cable and everything works perfect now.
    Total time in use : 71h :)
  13. Chris Chopping
    Chris Chopping Member
    Mechanical Engineer
    Melbourne, Australia
    - 26Coins
    Awesome rig Skuldi ! Nice and detailed forum with vids
  14. Skuldi
    Germany NRW
    265Coins
    Around may one gearbox got broken and the other one got a bit noisy. took a while but with @Bastiuscha help, i got new replacement gearboxes.
    I also finished a small flight sim update :)
