Question How is the MaxMin.cfg values calculated?
Discussion in 'SimTools DIY Version' started by BrassEm, Sep 5, 2020.
  1. BrassEm
    BrassEm G-Seat + SFX100 Builder Gold Contributor
    NE of YMML
    1,102Coins
    DC motor, AC motor, 4DOF
    Apologies if this has been covered before. Please see the image for references.
    I need to adjust the max min values of my axis for the sending value of the sim application. My axis is zeroed mechanically and electrically to the middle of travel as a standard start point for all applications as shown in the range values.
    I have a max value of 2.5 and a min value of -0.5 that I need for full scale deflection motion. I add these values to the maxmin.cfg file for the axis. Does SimTools calculate the FSD as per A or B? For A where the zero point stays in the middle or B where the zero point is offset.
    Thanks.
    153,722Coins
  3. BrassEm
    NE of YMML
    1,102Coins
    Unfortunately the post only mentioned full scale ranges, not what happens in between. Only yobuddy could answer this I think since he wrote the coding.
    153,722Coins
    Which is why I tagged him in my response, that way @yobuddy will get and automatic notification :thumbs
  5. BrassEm
    NE of YMML
    1,102Coins
    Thanks noorbeast for your ever vigilant support! :thumbs
  6. yobuddy
    51,523Coins
    @BrassEm,
    It's A buddy, the center is always zero.
    Let me know if you have any more question man!
    Take care,
  7. BrassEm
    NE of YMML
    1,102Coins
    Thanks yobuddy, that explains a few things. Now that I understand what is going on I can adjust using software with the max min range to suit then offset the zero point.
