Showroom My 3 DOF first time project
Discussion in 'DIY Motion Simulator Projects' started by Petemnz, Sep 12, 2019.
  1. Petemnz
    Petemnz Member
    Sparky by Trade
    Auckland, New Zealand
    60Coins
    What happens when testing and you can't set cutoff to more than 255 and comes off edge of slide frame. Was working well in AC until this happened.
    Magic smoke escaped so next project is to extend frame.
  2. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Thanks to @steveh2112
    find this line in the main loop() function
    Feedback1 = analogRead(FeedbackPin1);
    add the following after
    Feedback1 -= 512; // STEVE Feedback1 is 10bit, 512 is center
    Feedback1 *= 2; // STEVE scale range by 2
    Feedback1 += 512; // STEVE
    do the same for Feedback2 and Feedback3 if you need it
    now your pots will have twice the effect as before
    (remember to download it to the arduino)
    This temporarily solved my issue with feedback not reaching clip and cutoff limits on my traction loss motor.
    Extending frame to allow full travel and a loose 10k pot connection was the root cause.
  3. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Upgraded loss of traction (doubled) and aligned wheels to direction of travel , much freer movement.
    Also changed to steel slider plates as aluminum was to soft (bent and wore a groove in plate).
  4. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Video of Traction loss - on SMC3 motion testing.
  5. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Testing with Dirt rally 2 - pretty happy with result.
  6. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Iracing Bathurst Lap
  7. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    View of the Simulator movement Iracing around Bathurst.
  8. Erik Middeldorp
    Erik Middeldorp Member
    sheet metal worker
    644Coins
    It says the video is private.
  9. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    It shows as public in youtube? Maybe it was still uploading.
    Here's youtube link
  10. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    One year later still going strong - now racing inVR
  11. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
  12. ChuckyP
    ChuckyP Active Member
    Chicago, IL
    748Coins
    This looks like a great resource for my first build. I will also be doing VR and I like the fact that this setup seems to have given you some trouble free enjoyment.
    any advice for a guy starting off down this road? I’ve been looking at the different builds on here and this seems very close to what I would like to start with.
    ChuckyP
  13. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Hi ChuckyP
    Read lots and start small , learn to weld if you don't know how already. Just do one thing at a time, don't rush it.
    I've gone off VR after I was playing dirt rally2 and I got very motion sick after 1 hour and needed 4 hrs plus to recover, felt sick just looking at it after that. Decided 3 screens are the way to go for long racing sessions.
  14. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    HI..i have same motor you have but mine not taking weight!, i mean its cant push me up
    151,461Coins
    +11,038 / 56 / -2
    Please post on your own dedicated build thread, and add full details of your rig, hardware and settings.
  16. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Hi, I weigh 100kg and the motors don't even get hot (just warm). I'd check your rigs balance if it's balanced right the motors are only lightly loaded.
