budget DIY 2DOF Wiper 24V Fiat seicento Seat
Discussion in 'DIY Motion Simulator Projects' started by tadek, Sep 5, 2020.
  1. tadek
    tadek Active Member
    574Coins
    Hi
    My first project will be small 2dof design
    budget with 2 24 v wiper motor
    Please
    Can anyone tell me where to find its characteristics ? :sos
    Wiper motor VALEO 404.027 24v MAN L 2000 (3 wiper)
    link:
    https://hansa-export.de/en/shop/swf-404027-wiper-motor-sw2l/
    paramets:
    Current
    24V DC
    Torque
    50 Nm
    Bolt circle
    72 Nm
    Model series
    SW2L
    Gear position
    LH
    EMV suppression
    151,479Coins
    +11,041 / 56 / -2
  3. tadek
    tadek Active Member
    574Coins
    Ok thak's I know about ground wipeer
    but now is too erly to think about this
  4. tadek
    tadek Active Member
    574Coins
  5. tadek
    tadek Active Member
    574Coins
  6. tadek
    tadek Active Member
    574Coins
    Steering stick from unknown car will be main joint.
  7. tadek
    tadek Active Member
    574Coins
  8. tadek
    tadek Active Member
    574Coins
    Pot 10Kom is in Imbus fi 4mm
  9. tadek
    tadek Active Member
    574Coins
    Stand from office seat
  10. tadek
    tadek Active Member
    574Coins
    seat from seicento
  11. thanh tin
    thanh tin New Member
    173Coins
    great, I can't wait to see your project
  12. thanh tin
    173Coins
    the seats are a bit heavy
  13. tadek
    tadek Active Member
    574Coins
    it look too light?
    special Steering stick?
  14. tadek
    tadek Active Member
    574Coins
  15. tadek
    tadek Active Member
    574Coins
    I unmounted all the metal monsters
    to be not hevy
  16. tadek
    tadek Active Member
    574Coins
    please give mi a hint :think
    What is real angle of the leaver?
    I think 180 degrees is too much ?
    Thanks for help:sos
    151,479Coins
    +11,041 / 56 / -2
    A lever provides maximum torque when parallel to the seat with the rod at 90 degrees anything over 38-40 degrees up or down from there is very inefficient use of torque.
  18. tadek
    tadek Active Member
    574Coins
    thank's
    It mins that i can use angle of 90 degress ?
  19. tadek
    tadek Active Member
    574Coins
    m=r x f sin(fi)
    151,479Coins
    +11,041 / 56 / -2
    Closer to 75-80 degrees total is about the max range before torque efficiency drops dramatically, which just results in unnecessary strain on the motors.
