Question I added The Crew 2 game and my motion stopped working with all games
Discussion in 'SimTools Pro & Entertainment Version' started by PEB, Sep 8, 2020.
  1. PEB
    PEB New Member Gold Contributor
    - 78Coins
    4DOF
    Just checking my SimTools stopped work within games but still works when I am doing output testing on SimTools. I was wondering what could have caused it to stop working with the games completely. Assetto Corsa, BeamNG, Aerofly FS , F1 2018 and NoLimits 2 have stopped working. Is there anything I need to do to rectify this situation. I tried powering down and restarting no luck.
  2. PEB
    - 78Coins
    4DOF
    I wanted to add Game Manager is not connecting.
  3. PEB
    - 78Coins
    4DOF
    One more thing I did find out that my IP address changed so I went and updated it and patched the games all over again.
  4. yobuddy
    51,001Coins
    If your running a single PC setup of SimTools then both IP addresses should be 127.0.0.1.
    Is that what yours are set at?
    Chat soon,
  5. PEB
    - 78Coins
    4DOF
    Thank you I will make the change I was not using local setup will change it.
  6. PEB
    - 78Coins
    4DOF
    Fixed thank you being new I forgot how gameEngine needed to change the IP too.
