Tutorial Jorge's rig
Discussion in 'DIY Motion Simulator Projects' started by Jorge de Marchena, Jul 14, 2020.
  1. Jorge de Marchena
    Jorge de Marchena Hobbiest Gold Contributor
    Electronic Engineer
    Estados Unidos
    187Coins
    I forgot to metion that i'm using @BlazinH, SPC-Softstart app for arduino
    151,479Coins
    +11,041 / 56 / -2
    What motors are being used?
    And with Sabertooth 2x60 are you using a battery to manage regenerative current?
  3. Jorge de Marchena
    Electronic Engineer
    Estados Unidos
    187Coins
    @noorbeast
    I'm using Tarp Motors on the market! 12 VDC, 2 HP, 1200-WATTS, 40 AMPS, Reversing Gear Motor, 50 NM Operating Torque and a 90:1 gear ratio.
    And i'm not using a battery, i'm using a 1600 Watt Bitmining Power Supply
    Thanksfor your prompt reply
    Jorge
  4. Jorge de Marchena
    Electronic Engineer
    Estados Unidos
    187Coins
    Also, motor 2, its not working at all!!!!
  5. Jorge de Marchena
    Electronic Engineer
    Estados Unidos
    187Coins
    Motor 2 results
    151,479Coins
    +11,041 / 56 / -2
  7. hooshang
    hooshang Active Member
    275Coins
    hello Jorge
    i donno much about your configuration but at first look you have wrong numbers
    in the SMC3Utilitis.IMO for example first you have to try PWMmax between 150 & 255,
    MAXlimit and Clipinput to 0 with care!others seems OK for now,
  8. Jorge de Marchena
    Electronic Engineer
    Estados Unidos
    187Coins
    Jorge
  9. Jorge de Marchena
    Electronic Engineer
    Estados Unidos
    187Coins
    I will try.
  10. Jorge de Marchena
    Electronic Engineer
    Estados Unidos
    187Coins
  11. Jorge de Marchena
    Electronic Engineer
    Estados Unidos
    187Coins
    @noorbeast
    Sorry i had a wrong connetion, inverted the feedback. Let me correct and let you know. Thanks
