Question Help Frex and Simtool 2.4.1
Discussion in 'Commercial Simulators and Peripherie' started by fledge2b, Sep 10, 2020.
  1. fledge2b
    fledge2b New Member Gold Contributor
    Nagoya
    603Coins
    3DOF, SCN5
    I'm sorry if you have any questions already mentioned. I also don't know if it's appropriate to have this thread here.
    I'm running Frex's moving sim with a simtool. It worked fine with older versions of simtool, but after upgrading simtool to 2.4.1, it no longer recognizes it. I don't know what caused it. Does anyone have a similar problem?
  2. fledge2b
    Nagoya
    603Coins
    3DOF, SCN5
    My settings look like this.
    153,764Coins
    +11,149 / 57 / -2
    Does Output Testing work as expected?
  4. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    When you open Game Engine? Does it do the test of actuators? If so, try to move actuators with Output Texting as Noorbeast mention- Also try to unpatch and repatch the game.
  5. fledge2b
    Nagoya
    603Coins
    3DOF, SCN5
    Thanks for the advice. In the previous version of simtool, the initial operation was done immediately after launching simtool. It doesn't work at all since 2.4.1. It also does not respond to Output testing. I wonder why?
  6. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    Maybe you need the "net framework" to be updated or change ports. Just "try and error" everything you can, like changing usb cable ports
    153,764Coins
    +11,149 / 57 / -2
  8. fledge2b
    Nagoya
    603Coins
    3DOF, SCN5
    also I have a alert
    One of your interfaces requires simtools to be restarted
  9. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    It happend to me once , I needed to change comport numbers you have 3 actuators and 4 ports showing, Maybe one of them is not the correct one so simtools wont even start the check out
    153,764Coins
    +11,149 / 57 / -2
    That means one of the SCN's can't startup, or has not initialized.
  11. fledge2b
    Nagoya
    603Coins
    3DOF, SCN5
    Do I show 4 ports? I use No2,5,7 3 ports. isnt it?
  12. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    Yes and that could be that the comports are incorrect or that one of the actuators is not working (broken, bad connection etc) For me it was the comport on simtools, he has (7, 2,5) not corresponding to the usb serial port number showing. he has ( 2,5,6,7) in windows. Maybe changing the 2 comport to the 6 COM is the solution. Fledge, just be patient and try everything.
  13. fledge2b
    Nagoya
    603Coins
    3DOF, SCN5
    Thanks hideki.
    I try hard and hard.
  14. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    Man Its frustrating sometimes but I am sure your actuators are not broken its just the connection, Check the cables, check if the aluminium boxes have the green light on, not red, I always desconnect and connect again the actuators power supply, check usb connection and sometimes even restart the computer. Sooner or later it will work
  15. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    I never had frex controller but in Simxperience 3000 controller I remember Windows shows 4 ports, one it is the controller itself and 3 COMs more that are always in consecutive numbers for each actuator. So, if i had your problem, I would be trying PORTS 5, 6 and 7 because my simpxerience controller main port would be the COM 2 (you showed in your fotos), Then if it doesnt work I would try everything else. That was my experience with Simxperience controller and SCN actuators. Maybe frex uses just one COM for each actuator. Now, I use DIY controllers that windows place COM ports numbers quite ramdomly. Good luck!
  16. fledge2b
    Nagoya
    603Coins
    3DOF, SCN5
    To Hideki and noorbeast.
    Thank you for your advice. After clearing all the settings and re-entering them, it now responds. I don't know why, but I'm very happy. Thank you very much.
  17. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    You are welcome,Fledge, People here are wonderful, always trying to help especially Noorbeast and the moderators spend lots of their time in our probems. Now enjoy!
