budget DIY 2DOF Wiper 24V Fiat seicento Seat
Discussion in 'DIY Motion Simulator Projects' started by tadek, Sep 5, 2020.
  1. tadek
    tadek Active Member
    574Coins
    mounting the arm to the gearbox
      201.4 KB
      354
      165.7 KB
      338
      178.2 KB
      333
      226.2 KB
      340
      210.2 KB
      332
  2. tadek
    tadek Active Member
    574Coins
    Do I think right?
    151,467Coins
    +11,041 / 56 / -2
    Yes, though about 80 degrees total is the more effective range for torque use.
  4. tadek
    tadek Active Member
    574Coins
    Today
    today i made 2 arms
      243.4 KB
      312
  5. tadek
    tadek Active Member
    574Coins
    wiper motor mount
      174.3 KB
      324
      174.3 KB
      328
  6. tadek
    tadek Active Member
    574Coins
    wiper motor mount
      216.8 KB
      320
    151,467Coins
    +11,041 / 56 / -2
    You can make options for the Center To Center (CTC) hole distance from the shaft to where the rod mount, but as you are using wiper motors, which are not very powerful, start small at around 40mm CTC, as the larger the CTC the faster the linear speed, but less torque. You can always increase CTC after initial testing if the motors can handle the mass being moved.
  8. tadek
    tadek Active Member
    574Coins
    Thank you
    for advice
    I was thinking of 3 mountings (CTCs) at the following distances
    35mm
    50mm
    75mm
    best regards
    Tadek
  9. tadek
    tadek Active Member
    574Coins
    Wiper motor mount
    differences in the holes for the engine
    3mm sheet
    6mm mounting holes
    for screws x 6
      211.8 KB
      319
  10. tadek
    tadek Active Member
    574Coins
    Base leg filling
      322.6 KB
      318
      238 KB
      285
      161.9 KB
      311
  11. tadek
    tadek Active Member
    574Coins
    Fastening leg holder
      187.7 KB
      303
      184.1 KB
      307
      149 KB
      294
  12. tadek
    tadek Active Member
    574Coins
    Mounting motors to mounts
      224.3 KB
      303
  13. tadek
    tadek Active Member
    574Coins
    lever with handle
  14. Lgars39
    Lgars39 Member
    Jura
    208Coins
    a very good idea for those who lack space!
  15. tadek
    tadek Active Member
    574Coins
    Big thanks to Noorbeast :cheers
    motors ground isolation:
  16. tadek
    tadek Active Member
    574Coins
  17. tadek
    tadek Active Member
    574Coins
  18. thanh tin
    thanh tin New Member
    173Coins
    This idea is great, I also thought of using the seat instead of the metal frame because it is convenient
  19. tadek
    tadek Active Member
    574Coins
    thank you
    okay
    it will probably be much lighter
    the big problem is blocking the seat rotation
  20. tadek
    tadek Active Member
    574Coins
