Project Cars 3 v2.0
Game Plugin for Project Cars 3
  1. yobuddy
    51,524Coins
    yobuddy submitted a new resource:
    Project Cars 3 - Game Plugin for Project Cars 3
    • Like Like x 7
    • Winner Winner x 3
    153,758Coins
    Nice one @yobuddy, that will make some members very happy :thumbs
  3. yobuddy
    51,524Coins
    Special thanks to @Sarge for the testing and Min/Max tuning :thumbs
  4. Andriati
    Andriati New Member Gold Contributor
    São Paulo - Brasil
    - 394Coins
    thank you I will test here
  5. Lgars39
    Lgars39 Member
    Jura
    208Coins
    Thank you very much for the work
  6. Michael Maggio
    Michael Maggio New Member Gold Contributor
    usa
    10Coins
  7. Foxyfoxy
    Foxyfoxy New Member Gold Contributor
    - 115Coins
    2DOF, DC motor, Arduino, 4DOF
    it doesn't work for me, game manager goes to blue but no effects in virtual axis
  8. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    I had the same problem. Switch UDP on and it works. @yobuddy What is the correct setting nr 5 ?
  9. Foxyfoxy
    - 115Coins
    thanks
    great now it works, i set on 1, was fine for me
  10. yobuddy
    51,524Coins
    The faster the better I'd say.
    So i would go with 1 also.
  11. Boris Tattoo
    Boris Tattoo New Member Gold Contributor
    Belgium
    - 320Coins
    hello i have a problem with the patch: on my setup the pitch is inverted when playing on pcars3 ...no problems with pitch or else on pcars1 or 2 or other games.
    i unpatched, repatched, reinstalled simtools...nothing changes.
    I don't fknow how to fix the issue.
    i play on prosimu t1000 5m.
    153,758Coins
    The DIR box in Axis Assignment being checked orange or not determines which way each axis moves, so reverse whatever are your DIR settings for pitch for PC3.
  13. Boris Tattoo
    Belgium
    - 320Coins
    waw thanks for the fast answer i will try this.
  14. Boris Tattoo
    Belgium
    - 320Coins
    doesn't seem to work but i just realised on profile editor, pcars 3 using port 5606 .
    all my other games are on port 4123.
    could this be the origin of my problem?
    how to fix this ?
    thanks in advance
    153,758Coins
  16. Boris Tattoo
    Belgium
    - 320Coins
    im trying to send the pics
    actually it wont work at all...
    port 5606 is certainly the problem...
  17. Boris Tattoo
    Belgium
    - 320Coins
    yess
  18. noorbeast
    153,758Coins
    Glad you got it working :thumbs
  19. Boris Tattoo
    Belgium
    - 320Coins
    euhh no just good pictures sending...lol
    everything should work but don't.
    is the 5606 port normal? all working games are on 4123. any idea on how to change this?
    i reinstalled the game, nothing changes.
    on witch folder does the patch make changes? (perhaps to delete it and reinstall?)
    sorry for this.
    thank you for help
  20. yobuddy
    51,524Coins
    Its perfectly fine buddy.
    Not all games use 4123, since we can see data coming into tuning center in your pics above, so we know the port is right.
    None, as it requires some in game settings.
    You mentioned above
    So @noorbeast was correct when saying you just need to check (or uncheck) the direction boxes for pitch in your axis assignments.
    Hope that helps.
    Take care,
