6dof joystick
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Tino, May 11, 2014.
  1. Tino
    Tino Member
    1,289Coins
    I've seen a couple of interesting videos about Stewart Platform 6dof joysticks:
    http://lynxmotion.net/viewtopic.php?f=20&t=7517&start=30#p74136
    This should work great for space sims, it would also be a very good use for your 6dof test platforms, once you have built a full size simulator!
    There is currently no Force Feedback joysticks on the market (last one I believe was Logitech G940), especially no 6dof joysticks that I've heard of.
    Anyone else thinks that it would be cool to have a diy 6dof joystick?
  2. Tino
    Tino Member
    1,289Coins
  3. traveltrousers
    traveltrousers Active Member
    Timbuktu, Tombouctou, Mali
    890Coins
    my version :)
  4. Scratch
    Scratch Active Member
    281Coins
    Traveltrousers, that is cool!
  5. eaorobbie
    20,502Coins
    Well done any chance on sharing the idea, if not do understand, nice concept.
  6. Tino
    Tino Member
    1,289Coins
    Great project, have you thought about adding FF motors or do you plan to use only springs?
  7. eaorobbie
    20,502Coins
    I actually have one in protype myself for a different application that is being developed for SimTools, make use of an Ard and 6dof reader. You just plug it in and hold the box in space and as you move it , it send serial signals to an app that then records it for motion data.
    Its not a joystick but the Ard code could be modified into a joystick code. Possible, but I do like @traveltrousers a lot. Has the same potential to be use for the same application.
  8. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    I can not wath the video,why?
    153,728Coins
    If you are in China that may be because of restricted access to sites like YouTube, which is where the video is hosted.
  10. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    I understand ,thank you .I have an idea.
