FlyPT Mover 3.5.3
  1. Trigen
    Trigen Active Member
    2,892Coins
    There's more than heave going on yes. The video was made to illustrate how it felt being shot down in DCS. DCS is worse than that without a spike filter ofc.
  2. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    Hi ,@pmvcda , I have the same problem , No connection , I have this version 1.0 . ( Flypt mover 1.0)
    Is it the last version ? and where they are ?
    Thanks again for your help !
  3. djbart82
    djbart82 New Member
    Operador
    28029, Madrid
    210Coins
    3DOF, Motion platform
    Hello
    is it possible to play f1 2020?
    Thank you
  4. pmvcda
    15,660Coins
    @Flymen and @djbart82, I will release a version with F1 2020 among others and with other corrections in the next days.
    It's not what I wanted to release, but I'm short in time
  5. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    Hi ,
    Ok , my problem was I had the old version 1.0 , now with 1.1 from last version 2.99 FlyPt everything is ok with simtool.
    Thanks !!!
  6. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    Hi again !:blush
    when you get on in your simulator (low position), you active your outputs and your rig goes in middle position with you. But when you quit the simulator, you cannot do the reverse due to your weight. For me , what I do before going down, I put Drive pose (Heave) at -300 just before the low limits switch (like 5 cm over) then I desactivate the outputs.
    Question ... do you have another solutions for me or what you do if you don't want to hit hard the low switchs ?
    Thanks again !
  7. pmvcda
    15,660Coins
    Yes, in the rig module you can set the drive pose and the park pose.
    Park pose is the pose to where the rig moves when you stop the output.
    You can put the rig in the pretended pose and press the button, or since we limit the pose, making impossible to move to the desired one, you can set the actuators positions for the park pose.
    Drive pose is the middle position.
    That one, you set by pressing the button in the pose you want or changing the values manually:
    This is the new version, but I think you can do it already on the current version you have.
    I use drive pose to set a more horizontal position or vertical depending on the car I use (formula car vs GT car).
  8. Trigen
    2,892Coins
    Iracing Dallara LMP2 Profile PT mover tuned on Nordchleife. Needs motion cancellation for VR. Time spent 4 hours.
    This is a very aggressive profile focused on the best possible feel for elevation changes and bumps. It has sway up to 30 degrees. Tune smoothing filter to your liking.
    No global spike filter. It is adjusted for each force to get the most out of each. I run a 3x setup so just merge with your SFX and output setup. Software motion cancellation tracker output is included. Tune sway to your liking. Reduce Heave to your liking/range or turn it off. I have 150mm throw so got a bit more to go on.
    If you got neck issues, do not use it.
  9. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,445Coins
    AC motor, 6DOF
    I hope this is not out of place. I am building a 6 dof rotary. I have built the base and I am trying to figure out the best dimensions for the upper platform. I will most likely use 600mm rods.. I have the latest Mover software installed. Is there a design "helper" to figure out the best dimensions to avoid crashes while maintaining good movement? Or is it just not very critical. Just need some pointers..:o:
  10. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,782Coins
    DC motor, 6DOF
    There is a risk, your legs will collide with the plates. I would reduce the size.
    Also I advise to fix the gearbox to the frame vertically. The attachment of your plates could have rigidity issues
  11. Historiker
    9,214Coins
    Just gotta share the love: Absolutely loving those little things that Mover brings to the table...er...simpit. Pose from Airbrake for instance in DCS. LOVE the buffeting that I get when the airbrakes are out. Never again will I forget to pull them in on the F-5E3 Tiger II or the F-86F Sabre (both of which spawn with the boards out). Same for gear, and flaps.
    Freakin loving it. Thank you @pmvcda for you hard work! Very much looking forward to the next release so I can add Mover to my 2DoF (two rear rotational motors) simpit as well.
  12. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Oh yes, me and my 2DOF horse are waiting so much of this tool update. I hope, i can get flypt to work. One of the biggest reasons, is the virtual tracker feature. Can't wait to use it, to maximise my bassshaker again, without oscillating image. :)
  13. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    Where would you consider to be the COR on a PT Actuator look alike rig 3dof with TL and Surge. Also how would you define that if using a loop for testing?
  14. hexpod
    berlin
    7,782Coins
    DC motor, 6DOF
    This is my cessna 172 phyphox experiment.
    One could for general aviation reduce by a half the gyro zoom as we might never experience angular rotations above 0.3rad/s
  15. hexpod
    berlin
    7,782Coins
    DC motor, 6DOF
    End of the experiment
  16. Alexander Asner
    Alexander Asner New Member
    271Coins
    3DOF, SCN5, SCN6
    I have an SCN based 2DOF + traction loss simulator (2 actuators at the front and one for traction loss, none at the back). Will mover works with such a setup or will I run into problems?
    I also have an additional seattime belt tensioner.
  17. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    Hi , @pmvcda
    I would like to know which difference between those two things ( Distance to CG and Center rotation )!
    Thanks !
  18. pmvcda
    15,660Coins
    The objective is the same, I would use the cor for small distances, like under 50cm.
    The source distance for larger distances.
    It's the case for air crafts where you can be 15 or more meters ahead of the cg.
    When you use the source one, the accelerations are adjusted for it and include centrifugal and tangential accelerations corrections. So all the filters used in the pose are made taking it into account, while in the cor, you have no idea of the scale of the corrected forces.
    The result is there also, but no way to use the filters.
    Also, the distance depends on the vehicle, and that info might be available in some sources, so it's automatically adjusted in some sources.
    You can use both at the same time also. In the cor you adjust the center to your neck (recommended by some), since it depends on the rig, but be aware, that not all rigs can have the cor adjusted in all directions.
    I'm not good at explaining it. Hope you understand what I mean.
  19. hexpod
    berlin
    7,782Coins
    DC motor, 6DOF
    I understand it this way :
    While “center or rotation” concerns YOUR position on the rig, the “center of rotation displacement” concerns the VIRTUAL center of rotation in the game.
    For me “center of rotation” makes sense if you have a “sinked cockpit” or if due to mass distribution you belly is not exactly above the hexapod center on the longitudinal axis.
    “CoR Displacement” function adds a nice math with slight centrifugal forces on translations.
  20. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    Hi ,@pmvcda
    Exemple with Project Car 2 , I like when I put my COR front of my Rig (2000mm)
    And drift each side like a racing car. But when I push on gaz ( mix surge and pitch), I can’t feel the real pitch like a car does ( COR in middle of Rig) .
    Q- Is it possible to do Both movements with two different COG or COR ?
    See pic for exemple !
    Let me tell you , with 2000mm front of my Rig, when I used 3 degree Pitch it was
    Only up and dowm step :grin
    Thanks !
