  1. Jorge de Marchena
    Jorge de Marchena Hobbiest Gold Contributor
    Electronic Engineer
    Estados Unidos
    187Coins
    I haven't use sismtools yet, but maybe its a problem with the IBT_2, i used them but also the rsults where erratic, and i deside to mobe to sabertooth, before of that is used MMotorshield, but again the quality was verry poor. Whish you luck..
  2. SeatTime
    What version of Simtools are you using? - if 2.4.1 then it had issues with the serial link when released, so I had to roll back to 2.4. I although do not know if this was later fixed.
    153,764Coins
    +11,149 / 57 / -2
    Your SMC3 Max and Clip settings are not what I would expect.
    There are some reasons to reduce Axis Limiting for the likes of SCNs, to prevent damage, but not really for wordrive DC motors.
    There have been some slider related issues reported for the latest version of SimTools, following a recent Windows update: https://www.xsimulator.net/communit...04-from-1909-intensity-slider-problems.14795/
  4. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,557Coins
    Yep, Windows 10 2004 patch + simtools 2.4.1 does this. The serial component was broken in 2.4.1 with the introduction of 32 bit support. Roll back to 2.4.0 and it will be fine.
  5. MuñozChile2dof
    MuñozChile2dof 2 DOF SIMULATOR ARDUINO AND IBT-2
    Hydraulic technician
    CHILE
    54Coins
    Hi Noorbeast, thanks again for the fast reponse, the Max and Clip settings are low just in that screenshot, i have higher values in the normal configuration, sorry for post this image.
    Thanks for the info of the version of Simtools i check that tonight.
  6. MuñozChile2dof
    CHILE
    54Coins
    Good news, the problem was resolved by installing Simtools v.2.4, thank you so much guys, in the nexts days i will post the photos of my project.
    Thanks again!!!!
  7. Rav3n87
    Rav3n87 Active Member
    723Coins
    hello,
    Thank you for the great tutorial,
    i have a small issue... following your guide at the beginning i set everything to 0 and 255 then plugged power in and my motor instantly started running, im unsure as to why though,
    I am using the md30c motor drivers along with @Blame73 code adjustment, Using hall effect pots: 6127V1A180L.5FS
    the pot seems rather ridiculously sensitive in the center to the point where the motor controller flashes both direction Leds at the same time and the motor buzzes i cannot seem to get it shut down?
    If anyone can help i'd be forever grateful!
    EDIT: GOT THAT BIT WORKING!
  8. elnino
    Computer Geek
    Adelaide, Australia
    1,557Coins
    i had similar with smc3 code. the problem is that the arduino resets when the serial port is opened and this creates a dangerous situation where the drive pins can be powered, causing the motors to rotate uncontrolled. my sim totally flipped over backwards in a blink. there is a way to prevent this, google it. or, only power motors after simtools is active, this also goes for the smc3 utility.
    either that or your pots/hall are inverted. rotate your magnets 180 deg.
  9. Alexlam77
    Alexlam77 New Member
    - 66Coins
    Hi guys, can you please direct me on how to select MODE2 on smc3 arduino code? It says to edit the code at the top but I'm not sure what I'm editing? Please help. Screenshot_20200922-211608_Chrome.jpg
    153,764Coins
    +11,149 / 57 / -2
    Set Mode2 in the code like this:
    153,764Coins
    +11,149 / 57 / -2
    If SMC3 works as expected and SimTools does not the please start your own thread and post pictures of all of your settings.
  12. Alexlam77
    - 66Coins
    Thank you so much! I was scratching my head and thought it'd be more complicated. Lol
  13. noorbeast
    153,764Coins
    +11,149 / 57 / -2
  14. Manuel Quiterio Sousa
    Manuel Quiterio Sousa Maqs Gold Contributor
    - 276Coins
    3DOF, DC motor
  15. Manuel Quiterio Sousa
    - 276Coins
    3DOF, DC motor
    Hi Rufus.
    I am using the pololu drivers and just need to know how to connect the logic 5v to this driver
  16. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Can I just clarify, are you using a Pololu board and if so which one, as SimTools supports JRKs using the Pololu setup software.
  17. Manuel Quiterio Sousa
    - 276Coins
    3DOF, DC motor
    Hi. I'm using the Pololu G2 High -Power 24v21
  18. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Then just use the Pololu software to cofig, instead of SMC3, and select JRK in the Interface Settings to config o the SimTools side.
    See the JRK FAQ section for setup instructions and more: https://www.xsimulator.net/community/faq/jrk.8/category
  19. Manuel Quiterio Sousa
    - 276Coins
    3DOF, DC motor
  20. Manuel Quiterio Sousa
    - 276Coins
    3DOF, DC motor
    Hi. I am still lost. the pololu driver I'm using is the one in the photo attached. it doesnt seem to be a JRK .
