SimTools - What's Next for development
Discussion in 'News' started by yobuddy, Feb 16, 2019.
  1. noorbeast
    152,640Coins
    +11,087 / 56 / -2
    Do you mean this, if so it is a software tool that can aid understanding of SimTools settings:
    SimTools itself has several components, Game Manager, Game Engine, Tuning Center and some official companion apps to extend functionality: https://www.xsimulator.net/community/marketplace/categories/official-companion-apps.32/
    The SimTools manual is here and goes into a lot of detail: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    There is also other motion cueing software, like FlyPTmover, which can be used in conjunction with SimTools plugins, or totally independent of them: https://www.xsimulator.net/community/threads/flypt-mover.13464/
  2. gianlu320
    gianlu320 Member
    Crawley
    542Coins
    What I would like to see.....but I don't even know if at all possible.
    Talking about planes, for example DCS
    The possibility to have totally separate settings for in flight and on ground.
    I know we can adjust the on ground forces in the export.lua but it's still difficult to have everything perfectly tuned for both flight and ground.
    I am talking about having on ground axis adjustments and filters adjustments and in flight axis and filters adjustments .
    152,640Coins
    +11,087 / 56 / -2
    You may want to have a play with FlyPT: https://www.xsimulator.net/community/faq/flypt-mover.29/category
    Specifically with respect to DCS with ground and air: https://www.xsimulator.net/community/threads/flypt-mover.13464/page-3
  4. gianlu320
    gianlu320 Member
    Crawley
    542Coins
    Thanks for your answer noorbeast
    I am aware about flypt and I think it is an amazing piece of software.
    I also downloaded it and tried to make sense of the many options but I find it very complicated.
    This is not to say it's bad, quite the opposite, it is indeed very good but I find simtools much more user friendly and easy to use.
    I am a total noob with motion but I still find simtools understandable and intuitive.
    That's why I asked for this feature to be included in simtools.
    On top of that I believe a feature like this would only make simtools better, more complete and versatile.
  5. yobuddy
    51,230Coins
    Already included in v3 for all air type games :thumbs
  6. gianlu320
    gianlu320 Member
    Crawley
    542Coins
    Wow thanks a lot for that!
    This is very good news
  7. Shige Tanaka
    Shige Tanaka FREX Actuator Supplier http://www.frex.com/gp/ SimAxe Beta Tester Gold Contributor
    FREX
    Osaka Japan
    - 274Coins
    2DOF, 6DOF
    I would like to have a setting menu of neutral/starting potision of the Actuator. SCN and the family always stop at middle after calibration right now but want to have actuator start at fully extended position by some reason. Is it possible?
  8. yobuddy
    51,230Coins
    Do you mean a parking location?
  9. Shige Tanaka
    FREX
    Osaka Japan
    - 274Coins
    2DOF, 6DOF
    Yes! Where can I get if it is already existing.
    Thank you.
  10. yobuddy
    51,230Coins
    Hi @Shige Tanaka,
    It's in the v3 alpha that's not quite released yet I'm afraid, but it is there when released.
    We need to figure out what the output data for game dash is going to look like in v3.
    As I believe its the last major thing to be finalized before a v3 alpha release. :thumbs
    Take care,
  11. Shige Tanaka
    FREX
    Osaka Japan
    - 274Coins
    2DOF, 6DOF
    That's a great feature. I declare to be the tester. hug:
  12. PMK
    PMK Member
    Australia
    125Coins
    The updated UI looks great!
  13. iLLuac4
    iLLuac4 Active Member
    896Coins
    I hope it will also bring the updated DX12 plugins (F1 2019, 2020) with it otherwise it will not be a huge improvement if legacy technology will be still in use.
  14. yobuddy
    51,230Coins
    The core software is not affected by any one plugin, in fact the telemetry technically does not even have to come from a game.
    But yea, plugins will need to be updated and or reworked for v3, so I can take a peek at those titles when we get there.
    Take care,
  15. Mu-KwangKim
    South, Korea
    - 689Coins
    Wow. (C)Axis !!!
    Three overlapping motions are possible!?
    I'm looking forward to it!!
  16. The Iron Wolf
    The Iron Wolf Active Member
    Bellevue, WA
    375Coins
    3DOF, SCN6
    Is this something that's being looked at? https://ovrmc.dschadu.de/en/virtualtracker
    It might be a bit tricky to come up with a UI to define exact rig layout, but it would be so great if SimTools could write cancellation data out. Cheers!
  17. KydDynoMyte
    KydDynoMyte Fool's Gold Contributor
    RTP, NC
    50Coins
    What's sad is yobuddy looking at doing similar 2½ years ago and everyone not being excited and screaming "YES PLEASE!". Once it's working it seems to be the most loved method of cancelling out motion.
  18. yobuddy
    51,230Coins
    I just need to figure out how to update the virtual tracker with the proper memory mapped file.
    Once I know how to update the tracker, I can work out a UI for configuration.
    Give me a shout if anyone has the equipment for some tests, and wants to help work on getting this up and running.
    Take care,
  19. The Iron Wolf
    Bellevue, WA
    375Coins
    3DOF, SCN6
    I can help with MMF layout (struct marshaling) and writing it out in C#. Just let me know if you need that.
  20. pmvcda
    15,547Coins
    I defined it with @Dschadu for Mover.
    The memory file is 6 values in double format.
    So it's 6*8 bytes size.
    The name of the file should be "motionRigPose"
    The 6 values are:
    Sway, surge, heave, yaw, roll and pitch of the rig
    Problem is that we need to send those values, not actuators position.
    Alternatively we can do the same SRS does. They use a sensor in the rig. I'm buying one to test and implement in Mover.
    I think this might be the best solution for SimTools also.
    Some code:
    Code:
    //Create a shared memory file in c#
    this.MMF = MemoryMappedFile.CreateOrOpen("motionRigPose", 1024);
    this.viewAccessor = this.MMF.CreateViewAccessor();
    // Create array of bytes with needed data (something like that)
    var arrayList = new List<byte>();
    arrayList.Clear();
    arrayList.AddRange(System.BitConverter.GetBytes((double)sway));
    arrayList.AddRange(System.BitConverter.GetBytes((double)surge);
    arrayList.AddRange(System.BitConverter.GetBytes((double)heave));
    arrayList.AddRange(System.BitConverter.GetBytes((double)yaw);
    arrayList.AddRange(System.BitConverter.GetBytes((double)roll));
    arrayList.AddRange(System.BitConverter.GetBytes((double)pitch));
    // Write byte array to memory file
    this.viewAccessor.WriteArray(0, arrayList.ToArray(), 0, 48);
    Needs some error handling...
    If you need anything extra, just say. :thumbs
