Question Epic Rollercoaster
Discussion in 'SimTools Plugins' started by DarkHunter82, Jan 14, 2020.
  1. julioschwapp
    julioschwapp New Member
    - 7Coins
    Can anyone provide a tutorial how to make it work?
  2. julioschwapp
    - 7Coins
    norte me funcionaaaaa:(:(:(:(:(
    (Doesn't work for me)
  3. kevinmarz
    kevinmarz Member
    346Coins
    Hello...IS there a Simtool plugin for this game yet?:cheers:)
    151,991Coins
    +11,061 / 56 / -2
  5. kevinmarz
    kevinmarz Member
    346Coins
    Thank you,This plugin worked for me,I like it better then the No limit roller coaster ride.would be awesome if We had a driving game,where we could shoot stuff with movement!!LOL
  6. Larux
    Larux New Member
    Argentina
    - 1,215Coins
    Hello, for it to work, you must also activate telemetry in the game, in the telemetry option and change the value of 50010 or something like that to 4123 and then click on start. And solved
  7. Larux
    Larux New Member
    Argentina
    - 1,215Coins
  8. MarkusB
    4,215Coins
    Thanks a lot for this plugin, @value1. I gave it a try today and it works perfectly, including Game Dash.
  9. Drikeralex
    Drikeralex New Member
    Ukraine
    - 137Coins
    is it posible to add speed data? i want to connect it with speed of wind
  10. Claudioprogaimer84
    Claudioprogaimer84 New Member
    - 44Coins
    2DOF, AC motor, Arduino
    Hello how are you doing. Did Epic Roller Coaster work for you?
  11. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    550Coins
    if you want it to work, just patch the game, then enter game setting, telemetry, press start and enjoy
  12. Tomsix
    Tomsix Member
    Németország
    324Coins
    Have no Luck. For me doesnt work
    Patched -- IP and Port correct and Telemetry activated
  13. noorbeast
    151,991Coins
    +11,061 / 56 / -2
    Can you please post pictures of all of your settings, including the Tuning Center while the game is running.
  14. Tomsix
    Tomsix Member
    Németország
    324Coins
    No, a can not because the Steam Variation of the game didn't start anymore...( Disc write error)
    I need to try install itt from the Oculus library
  15. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, it works but the feeling is not terrible damage.
  16. Rainer Arbinger
    Rainer Arbinger New Member Gold Contributor
    101Coins
    Hi to all frustrated Epic Roller Coaster fans!
    The plugin @value1 provided ( thanks a lot for your work, @value1!!! ) worked very well for me until the update to the "World Championship Edition" of the Roller Coaster about 3 weeks ago.
    I`m using the old Oculus Rift CV1.
    In my OculusHome-Lib I suddenly had a second Epic-Roller-Coasters-Icon next to the old one.
    Starting with the first icon MotionSim still worked. Starting with the new icon SimTools detected the game is running but the axis output showed no activity.
    I tried almost everything, including a completely new Win10, Oculus, SimTools, Epic Roller Coasters and plugin installation, but with the new version of Epic Roller Coasters it does not work anymore.
    So I assume B4T had changed something that affects telemetry format or output and about two weeks ago I wrote a whining speech to B4T, but got no answer yet.
    Merry Christmas to you all and
    kind regards
    Rainer Arbinger.
  17. kevinmarz
    kevinmarz Member
    346Coins
    Any chance you didn't set up telemetry,In game...
  18. Rainer Arbinger
    101Coins
    Hi Kevin!
    Thanks for your reply!
    At least it shows me the thread is not dead yet. :)
    Of course I can not exclude a configuration error, but I tried telemetry settings for "default" and "SRS" and started telemetry output.
    Do you have the "World Championship Edition" and the latest update installed and does the plugin still work for you?
  19. Rainer Arbinger
    101Coins
    Hello everyone!
    I hope you survived the Christmas stress without physical and mental damage.;)
    Meanwhile I got a reply from B4T: They say they made some minor changes that could probably trigger an error in the plugin.
    B4T seems to be doing everything they can to help.
    B4T if you read this:
    Thank you for your efforts, B4t! Hug:
    Have a good New Year's Eve party!
    Rainer Arbinger.
  20. yobuddy
    51,001Coins
