value1
MotoGP 18 Plugin 2.0.0.2
SimTools game plugin for MotoGP 18
  1. value1
    14,236Coins
    MotoGP 18 Plugin - SimTools game plugin for MotoGP 18
  2. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    Hello Value1 and Wotever. I cannot make Simhub and Simtools work together in this game. I dont know how to change the 7100 UDP port inside the Motogp game or in Simtools so I could fordward it. Could you please explain how to do that? many thanks
  3. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
    its work on motogp 20?
  4. reinaldo rodrigues
    reinaldo rodrigues New Member
    12Coins
    DC motor
    Friend, do you know if this plug-in still works? If there is any specific configuration and what version of simtoos?
  5. long16652
    long16652 New Member
    - 220Coins
    The plugins posted here should all be used in version v2. V3 has a dedicated webpage for downloading plugins.
  6. long16652
    - 220Coins
    You can first point the UDP port of the game to Simhub, and then use Simhub's port forwarding function to forward to the port number required by Simtools.
  7. Henjamin
    Henjamin New Member
    34Coins
    DC motor
    Can you share more about how to configure the plugin to optimize the driving experience? Are there any settings you recommend to improve the accuracy of the motion data?
