Lesson T1000 3M comport issues
Discussion in 'Commercial Simulators and Peripherie' started by Nate Stokes, Oct 5, 2020.
  1. Nate Stokes
    Nate Stokes New Member
    39Coins
    3DOF, SCN6
    Hey anyone hope im doing this right I dont want to be banned im a total tech dummy but I love to race im having COMPORT issuse with my prosimu t1000 3m simtools keeps telling me I have to restart game engine
    153,986Coins
    +11,162 / 57 / -2
    Is your rig running and then shutting down, or not initialising from the get go?
    Can you please post pictures of any warning messages.
  3. Mver
    Mver New Member
    47Coins
    Motion platform
    i have the Prosimu 5M and had the same error message. In my case the interface port numbers where randomly assigned to the PRS200 and the SCN6. When i switched on my PC one moment the PRS200 got the port number of the SCN6 and sometimes the other way around after a power reset.
    I think this happened because which one was switched on the first got assigned the lowest port number of the two.
    You can change/check the comport number in Simtools under Game Engine, or what i did was swap the usb cabels on my PC.
    Since i now power on my PRS200 and SCN6 in the same order i don't have this issue anymore.
    I know you don't have the PRS200 but you might want to check your port numbers.
    Hope this helps.
  4. prosimu
    prosimu Member Gold Contributor
    - 940Coins
    Generaly, it's because simtools try to communicate with SCN6 without sucess : verify the power supply or the COM port number or if you have put 24V on the power supply.
    Patrick
