No movement within range of motion
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by chavilap, Oct 10, 2020.
  1. chavilap
    chavilap New Member Gold Contributor
    - 25Coins
    I have a problem that has been consuming me for months.
    I have a 2Dof with Arduino Uno, code SMC3, and wiper motors.
    The movement of the motors is as expected, but there is a range of approximately 30% (normally with negative values) where I do not get a response, but when I exceed a certain value, the movement becomes abrupt to recover the "missing values".
    When I run SMC3 Utils I have no problem, the movements of the motors are faithful to the entire range of motion.
    I have checked if it is a problem of the connection between simtools and arduino. I have also checked if it is a problem with the pots.
    If it's a power supply problem. If it is the baud rate, the windows region, ..
    I have checked and read the tutorials, but I think I must be doing something wrong.
    153,848Coins
    +11,152 / 57 / -2
  3. chavilap
    - 25Coins
    Thanks for your quick reply Noorbeast.
    The truth is that this morning I have been reading the post about the 2004 update óof windows. It may be this. I will investigate what updates I have made in the past.
    EDIT:
    I have already read the whole post about the win10 2004 update problem. We have to wait for a solution from Sim tools.
    153,848Coins
    +11,152 / 57 / -2
  5. chavilap
    - 25Coins
    Noorbeast, i'm going to give you an apartment in Marbella, jijiji.
    After several moths trying without success, my sim motion moves faithfull to the movements of the games.
    I have installed version 2.0 and it works correctly.
    Thank you very much Noorbeast.
