Bug I cannot use V2.4.1 and V2.5
Discussion in 'SimTools DIY Version' started by wp8051, Oct 20, 2020.
  1. wp8051
    wp8051 Racing simulator player Gold Contributor
    China
    224Coins
    AC motor, Motion platform, 4DOF
    My computer's operating system is WIN10, version 2004.
    I use 2 worm motors and 2DOF motion equipment controlled by ARDUINO.
    When I use SIMTOOLS V2.3.1 and V2.4, everything works normally.
    When V2.4.1 was released, I upgraded, and then in the software test, there were some problems, such as the completely abnormal motion range compared with V2.4.
    And click "CLR", the seat cannot return to the middle position.
    After that I went back to V2.4 and everything was normal again.
    Today I upgraded to V2.5, but the same abnormal phenomenon as V2.4.1 still occurred.
    So I can only fall back to V2.4 again.
    I only found abnormal phenomena in the output test, and did not enter the game. When the output test was abnormal, I never used V2.4.1 and V2.5 again.
    Excuse me, does any of you know how to solve this problem? Or I can only continue to use V2.4?
  2. yobuddy
    51,522Coins
  3. wp8051
    China
    224Coins
    Do you mean to uninstall the previous V2.4 first, and then install V2.5?
  4. wp8051
    China
    224Coins
    Do my previous settings in V2.4 need to be modified? For example, the interface settings?
    The situation I have encountered now is that after installing V2.5, the roll, pitch, sway, and surge are abnormal in the output test, and the seat is tilted to one side, and I cannot click CLR to return.
    Back to V2.4 will be normal.
    I have a few friends, they are using SIMTOOLS for the first time, and then they directly use V2.4.1, the result is that the motor movement is not normal.
  5. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    guys ... a user on the simtools 2.5 software topic is saying that by copying the serialinterface.dll file of version 2.4 the most stable in the same root address where you install it the program says that everything works perfectly .. until Let's not try we are not going to get rid of our doubts.
  6. wp8051
    China
    224Coins
    Great, buddy, thank you, I succeeded according to your method.
    love you!
    The effect of V2.5 is really great!
  7. wp8051
    China
    224Coins
    The author has released 2.5.1 and replaced the Serial_InterfacePlugin.dll file in 2.5. Now 2.5.1 can run perfectly. Thanks to the author yobuddy!
  8. Viper Mad Max
    Viper Mad Max New Member Gold Contributor
    Indiana, USA
    233Coins
    SCN5
    I too after the 2004 Win update, am having issues with the motion, now it is slow to respond, almost like it is lagging behind, and the range is much less than before, when bringing the car to a stop, the motion is still moving back to home, this is when in iRacing. If I go to the test area in Simtools all appears to work as it should. I saw the 2.5.1 update so I installed it and now I've lost all motion. I'm on version 2.3.1. and am using 2 SCN actuators.
    Any thoughts?
    153,716Coins
  10. wp8051
    China
    224Coins
    Hello, my computer has been reinstalled and the current version is WIN 10 20H2.
    I still find that V2.5.1 has some problems.
    I suggest you download and install V2.4 first, which is a very stable version, and then copy the file Serial_InterfacePlugin.dll in the InterfacePluging folder to another location on your computer.
    Next, you can uninstall V2.4, then reinstall V2.5, and cut the Serial_InterfacePlugin.dll file you just copied and overwrite the V2.5 file with the same name.
    After this, there should be no problem.
  11. Viper Mad Max
    Indiana, USA
    233Coins
    SCN5
    2.3.1 Interface 1.JPG 2.3.1 Interface 2.JPG 2.5.1 Interface 1.JPG 2.5.1 Interface 2.JPG
    The 1st 2 pics show how it was when using 2.3.1. The 2nd set of pics are how it came up after installing 2.5.1. Notice that the assigned axis is blank, I have it highlighted. When I click in that field it will allow me to select axis 1a and axis 1b respectfully. After that, I click save. When I close the game engine and then reopen it those 2 fields are blank again. Normally when I first start the game engine the actuators will move to their limits and center. Now they do not move at all.
    I'm thinking that those 2 fields not being able to be saved may be the issue. If not please let me know and I will load more screenshots.
    Thanks for looking into this.
    Brent
    153,716Coins
    @yobuddy is that expected behavior?
  13. yobuddy
    51,522Coins
    This is because the interface now supports 2 axis per interface. (different interface plugin)
    So the saved file is not in the correct format to save the new settings.
    To fix this, simply un-select the "SCN" plugin from the interface Type drop down. (Simply select the "-" option.)
    It will ask you if you want to delete the old settings, say yes.
    Then simply re-select the "SCN" plugin Interface type and re-setup your interfaces.
    Let me know how it goes.
    Take care,
  14. Viper Mad Max
    Indiana, USA
    233Coins
    SCN5
    yobuddy,
    That did the trick!
    Thanks so much!
    Brent
