DIY static to motion project for Heli Sim
Discussion in 'DIY Motion Simulator Projects' started by physke, Oct 10, 2020.
  1. physke
    physke New Member
    IT & Electronics Engineer
    Tauranga, New Zealand
    192Coins
    Planning on adding motion to my static sim mainly for heli flying. Also want to build new pedals, cyclic and collective controllers to replace the existing logitech pedals and HOTAS.
  2. physke
    physke New Member
    192Coins
    Received a few parts today ....
  3. physke
    physke New Member
    192Coins
    Finally received all the electronics and put them together in a recycled 1U rack case over the weekend.
    153,728Coins
    Very neat wiring work :thumbs
  5. physke
    physke New Member
    192Coins
    Received more parts and started the assembly. Couldn't easily find a universal joint, so am trying something different with a steel plate sitting on a heavy duty conveyor ball bearing.
  6. SeatTime
    I guess your building a balanced 2DOF? So you need something that will not twist - like a universal joint - which unfortunately is not as common in cars as it use to be. All the best for your build.
  7. physke
    physke New Member
    192Coins
    Correct. Got me thinking - maybe I could add another motor for yaw since it can twist already.
    153,728Coins
    That is possible and warranted if yaw is genuinely useful, which it would be for helis.
    Alternatively you could use panhard rods running diagonally from the top to bottom frame to prevent twist, it does add to cost and build complexity, which is why a universal joint is recommended.
  9. physke
    physke New Member
    192Coins
    Hall sensors arrived yesterday so finished putting the platform all together with a couple of liner actuators and a few other bits and pieces. Installed SMC-Utils, Simtools demo and LFS, and successfully set it all up and got it working in LFS. Next step is integration with DCS and XPlane.
