FlyPT Mover 3.5.3
  1. pmvcda
    15,647Coins
    I will release a new build today with some changes and will include the missing files.
    Trying to solve the disconnects in NoLimits2. :think
  2. deadlymanager
    deadlymanager Member
    10Coins
    Very!!!! Coooool!!! Not as DCS Worl, but not bad.
  3. deadlymanager
    10Coins
    I want translate FlyPT on Russian language. What can I do fo this???
    And second question, I write driver for Arduino 2560 while build my rig. It supply from 1 то 6 stepper motors with acceleration and speed. Who want???
    And Last question... where Warthunder plugin???
  4. pmvcda
    15,647Coins
    I'm interested in the driver. :)
    Translation: I'm working on it, to make it easy I hope.
    Warthunder: Is on the list, still not made.
  5. wyh0607b
    wyh0607b New Member
    173Coins
    AC motor, 6DOF
    Is there something wrong with this display?(FlyPT Mover 3.3.1 ALPHA)
  6. pmvcda
    15,647Coins
    Mover uses the windows system fonts.
    You are using a monospace font in windows,that's why you get this.
    I can try to force a font instead of system font.
    It should happen in other apps also and Mover forms
  7. pmvcda
    15,647Coins
    Mover 3.3.2 ALPHA
    - We can now select the IP to output data by UDP.
    Default is 255.255.255.255, that sends it to all networks and IP's connected to the PC.
    - Think I solved the noLimits2 disconnects.
    - Added missing Aerofly FS2 dll to the download.
    To setup Aerofly FS2, just copy the "FlyPT_AeroflyFS2_UDP.dll" to the folder "...\Documents\Aerofly FS 2\external_dll\"
    - To use Condor 2, you need to edit the setup file.
    Go to the folder: "...\Condor2\Settings\"
    And edit the file "UDP.ini" to match the following:
    [General]
    Enabled=1
    [Connection]
    Host=127.0.0.1
    Port=55278
    [Misc]
    SendIntervalMs=1
    ExtendedData=1
    ExtendedData1=1
    LogToFile=1
    - Updated transducers code to solve sudden crashes in Mover.
    Audio was initialising on Mover opening, now only when we use a audio device.
    Might still cause crashes. Needs testing.
    - Audio devices already in use by the transducers, show with a red mark.
    - Revised devices auto detection.
    Joysticks, audio devices and serial/parallel devices are detected automatically and lists update automatically.
    Even so, the update buttons are still present, but might disappear soon.
    - Forced font type and color on all windows. Not sure of the consequences if you select other fonts for windows.
    Other OS options might still affect Mover.
    - Other small bugs solved, nothing special.
    - Still some bugs, line line displacement in the sources info.
  8. digitalmonk
    digitalmonk Member Gold Contributor
    Canada
    239Coins
    So a question, i think have a pretty good motion profile for Dirt Rally 1, based on a sfx-100 platform. The one thing that kind of bugs me is that the motion feels a bit "Stepped" or choppy when going over jumps (full extension and compression). I'm sure it's to do with the filters that I'm using (I grabbed parts of profiles and combined them into mine). How would I be able to eliminate this choppy/sticky motion. Here are the different poses that I'm using along with filters. Also attaching my profile. Can someone help me tweak it?
  9. digitalmonk
    Canada
    239Coins
    Changed my heave filter to EMALP(EMAHP(VALUE;220);150.000), also closed down most of the pose windows and it's much better. Do the windows being open have an effect on the motion?
  10. mm982566
    mm982566 New Member
    US
    56Coins
    3DOF, 4DOF, 6DOF
    hi
    hello
    I come from China, my English is very poor, so I can only use the translation software
    I have now completed the change from English to Chinese
    RADIALIX can be used to translate and reconstruct the file, and you will have the language you want
    I hope this helps
  11. kunkurus
    kunkurus Member Gold Contributor
    Canada
    263Coins
    DC motor, 6DOF
    Condor source craches periodically and needs to disconnect and then connect again to work.
  12. pmvcda
    15,647Coins
    Thanks, I will look at it
  13. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    Big bug for me with version 3.3 .. the pc freeze !!:roll ( FlyPT Mover will close )
    Must erase the version2.9.9 before ?
    The last version 2.9.9 work very well again !
  14. pmvcda
    15,647Coins
    No, don't erase! 3.3.x is all alpha.
    Many bugs. Sorry
  15. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    Ok thanks !
    May be you will receive some call from Microsoft !!:grin ( windows try to repair this bug !!)
    Some errors I received :
    1 - Trying to connect to serial port( exemple com12 ). - * version 2.9.9 goes well
    2- Only axe 1,2,3 work or all goes up , top end and back low . and after only 3 axe goes in the middle .
    3- Pc freeze sometime .
    I hope this will help you !
    Thanks for your efforts !
    No Pain No Gain !!!!:)
  16. pmvcda
    15,647Coins
    What version are you testing?
    3.3.2?
  17. J-1775
    J-1775 Aviator
    1,582Coins
    WRT Flymen's remark "2- Only axe 1,2,3 work or all goes up , top end and back low . and after only 3 axe goes in the middle ."
    @pmvcda : I've mentioned a few posts ago that when connectiong POSE::FROM MOTION into OUTPUT::UDP only the changes in transational axes would result in change of output values, whereas the 3 rotational axes seem not to connect. Maybe for the same reason? Just my 5ç.
    I noticed you added IP address to OUTPUT::UDP, but not (yet) added a Bit input field (that you now renamed in the RIG modules as "Position bit output):
    BTW, in 3.3.2 I also noticed this funny behaviour that when I change the value the name changes back to how it was before:
    (both screenshots from the very same RIG::ROTATING HEXAPOD module window)
  18. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    version 3.3 Alpha
    Ok I will change for the new one 3.3.2
    15 min after ....
    :grin Good after this new version everything seem good ! (sorry , I never see the new version ):thumbs:cheershug:
  19. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    Hello ,
    For the moment with Condor2 AIR (UDP) ( version 3.3.2 ) seem goes well with Port=55278 and with Yaw speed ( Thanks Pedro) ! :thumbs
    Now I try to set up * Ground* ( I'm not sure if it's like that *set up* :think ) but , when I put a new Pose from motion for Condor 2 Ground ( UDP) , my Rig Bug . I need a new Port= ????? to switch motion on the ground ? If Yes , is it ;55279 ?
    - IF I want suspension on the ground, the source ( surface ) stay at 6.00 and don't move .
    Pic with my set up !!
    Thanks !!!
  20. pmvcda
    15,647Coins
    Wow what a mess... Sorry
    You open the condor source one time.
    That source shows 2x in the pose, one for ground and one for air
    Now you can define a pose for air and one for ground.
    I don't think it's worth for Condor2.
    To get the ground contact vibration, use a suspension module. Attach to it the ground pose.
    You get the surface type. Now add a NOISE filter:
    Now, you get vibration with an amplitude that depends on the ground value and speed (speed=0 no vibration)
    Play a bit with the filter. I did not make tests in Condor.
    Don't forget to add the suspension pose to the rig
    Some considerations:
    -Select surface type!
    -The noise depends on the surface type value. If 10, it generated movements with an amplitude of 10.
    -Some games don't have the values ordered. We can get 10 for clean asphalt and 2 for grass.
    So I had to reorder them in the sources. If you find strange results, please report, I might have to reorder it. Some games can have up to 20 ground types
