Question 360 degree cockpit
Discussion in 'Electronic and hardware generally' started by Özden Büyüksanalan, Nov 1, 2020.
  1. Özden Büyüksanalan
    Özden Büyüksanalan Member
    317Coins
    as i write in the topic i am going to plan (in my mind) a 360 DOF.
    My plan sees 2 rings eacht with one 3 kw motor.
    The Motor of the inner ring + all the other electronic like computer, Monitor and so on will also be in need of
    Power.
    My question is, before i go further with planing, if this item will give the required power for one PC and the 3 kw motor of the inner moving ring.
    Maybe someone has the knowledge to take a look at this and give me some advice.
    153,758Coins
    +11,149 / 57 / -2
    I think what you mean is how do connections work between moving parts, and that is slip rings: https://en.wikipedia.org/wiki/Slip_ring
    That said do plenty of research, as a 360 degree rig is complex, costly and without something like a G-Seat is pretty limited in terms of simulation. As a result 360 degree rigs are often discussed, but only rarely built.
  3. Özden Büyüksanalan
    317Coins
    I understand your point.
    I just wanted to know if this item has enough capabilities for the power that will go through it.
