MY own 2 dof diy
Discussion in 'DIY Motion Simulator Projects' started by absyfadhel1, Apr 17, 2020.
  1. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
    hi
    dcs world game not giving motion to my simtools.. this is my setting
    What's wrong?
    153,884Coins
    +11,154 / 57 / -2
  3. absyfadhel1
    bahrain
    556Coins
    simtools output work in nolimit2 ,lfs,assetto corsa , euro truck simulator 2 and X-plane11 ....but in dcs world there is no output and tunning center nothing moving
    153,884Coins
    +11,154 / 57 / -2
    Have you captured the Max/Mim and which DCS pllugin are you using, as there is more than one.
  5. absyfadhel1
    bahrain
    556Coins
    hi i use 2x powersupply for my 2dof setup and when in game fast movment the powersupply shutting down why ? i tryed to connect only one power supply and it was the same i change smc3 but nothing changed its still when there is rapid movment the powersupply turn off please help ..
    i used this type of power supply and i have mod it to 12v dc
    153,884Coins
    +11,154 / 57 / -2
    Our rigs tend to have significant power spikes, LED PSUs are not as sensitive to such surges as computer PSUs, or a battery can be used as a buffer.
    Another thing you can try is lower the % in Game Manager, as that is like adding in some global smoothing, try 95-98% and see if that stops the PSU tripping.
  7. absyfadhel1
    bahrain
    556Coins
    I use 20% on the game manager .. you mean pc power supply not good for 2dof? so i need to buy like this one and maybe resolved?
    is this one ok?
    153,884Coins
    +11,154 / 57 / -2
    Correct, a PC PSU is not a great choice, a powerful LED or general PSU is a better idea. Prices can vary a bit between cheap import LED PSUs and the likes of Meanwell.
  9. absyfadhel1
    bahrain
    556Coins
    hi One of the motors move more than the other, i mean when i open simtools and the seat is on the center and its ok but when i move the seat up its go up and a little left and when i move it down its go down and left not center!!
    in roll its same when i roll it to left its go in good movement but if i roll it to right its roll a little i dont know why??
    what i try:
    * reprogram the arduino
    *edit the setting on smc3 and cofirmed that the both motor is same setting
    * confirmd that simtools axis adjustment
    *change the percent for one of the motor and nothing helped
    this is my setting
    153,884Coins
    +11,154 / 57 / -2
    Just to clarify, in SMC3 the motors should behave the same, they may not have exactly the same settings. So do both motors move exactly the same in SMC3?
  11. absyfadhel1
    bahrain
    556Coins
    no when i put out manual and pull the blue dot up its work fine and smooth but when i pull it down a bit the motor move like i pull it so hard
  12. absyfadhel1
    bahrain
    556Coins
    This what happend when i play lfs see when its start to move and accednt break or car turn or shift up the powersupply turn off
  13. noorbeast
    153,884Coins
    +11,154 / 57 / -2
    SMC3 has to be fully sorted first, so go through the set up steps for each motor.
  14. Dschadu
    Dschadu Active Member
    1,937Coins
    It can be overcurrent protection or overvoltage protection. When your motor decelerates it acts as a generator and produces power. As the power has nowhere to go, the voltage rises. This can trip the PSU overvoltage protection. A work-around is a big diode in series directly after your PSU positive output
  15. absyfadhel1
    bahrain
    556Coins
    please can you explaine what must i do to fix it?
  16. noorbeast
    153,884Coins
    +11,154 / 57 / -2
    Did you try my earlier advice of reducing the Game Manager Intensity Level in the Profile Editor, like this:
  17. absyfadhel1
    bahrain
    556Coins
    Oh yes i already tryied that but i think its psu problme
  18. PMK
    PMK Member
    Australia
    125Coins
    What is your PSU rated for? What are your motors rated for? Make sure your PSU can exceed the maximum PEAK current that your motors can draw.
    You're probably also going to run into back EMF issues as Dschadu mentioned.
    You can purchase 2 of these (or similar)
    https://www.jaycar.com.au/400v-35a-bridge-rectifier/p/ZR1324
    and wire them like a diode from your PSU to your motors.
    Basically this 'blocks' any voltage being sent back into your PSU which can cause it to trip and shut off.
    Obviously if your PSU can't supply the current for the motors it's going to trip but this is necessary anyway.
  19. absyfadhel1
    bahrain
    556Coins
    Thanks alot for your advice ... where can i find a video for the blocks? I can get it from photot
  20. PMK
    PMK Member
    Australia
    125Coins
    It's going to be difficult to find a video on that wiring as you're not using a bridge rectifier like they are normally used.
    It might be worthwhile spending some time learning how to read circuit diagrams. You're basically just wiring the PSU to the negative terminal of the bridge rectifier and the positive terminal to the positive terminal of the motor.
