DIY Compact 6DOF Wiper 24V <200EUR
Discussion in 'DIY Motion Simulator Projects' started by tadeusz, Nov 13, 2020.
Tags:
  1. tadeusz
    tadeusz New Member
    34Coins
    hi
    My new design is a 6dof compact seat based on wiper motors.
    Basic assumptions:
    1. Soft - Sim Tools 2.51
    2. Arduino UNO SMC3 v1.0 x2
    3.BTS7960B x6 motor driver
    4. VALEO 404.027 wiper motor x6
    Best regards
  2. tadeusz
    tadeusz New Member
    34Coins
    Hi
    Actual-measured parameters of Wiper Motors
    VALEO 404.027
    TRQ- 10 Nm
    I [A]- 6A
    Current 24V DC
    Best regards
  3. tadeusz
    tadeusz New Member
    34Coins
    hi
    I have a question
    Do I think right?
    5 cm arm we will get strength = 10 * 100/5 =200 N ( 20kg)
    with 6 actuators we have 6 x20 kg = 120 kg
    at total load =110 kg
    110kg<120kg it's enough?
    Should I use telescop spring support?
    best regards
  4. tadeusz
    tadeusz New Member
    34Coins
    Hi
    Is it good idea?
  5. tadeusz
    tadeusz New Member
    34Coins
    Hi
    Is it good idea?
    Sim tools have support for hexapod?
    best regards
  6. RacingMat
    21,083Coins
    Arduino Uno has 6 PWM pins (3, 5, 6, 9, 10 and 11): you don't need 2 arduino boards
    yes, 10Nm torque with 5cm arm gives 20kg
    BUT 120kg vs 110kg is not enough
    and at what speed? max torque is achieve at lowest speed.
    Check the specs! here I readd 5Nm...
    that https://www.smolka-berlin.de/online...iper_motor,_gear_motor_24V_DC,_type_SW2L/5814
    Please add your location in your profile! we may advice you some place where to buy suitable motors
  7. tadeusz
    tadeusz New Member
    34Coins
    153,986Coins
    +11,162 / 57 / -2
    @aliaero has not been active since late 2012, so you are unlikely to find more information other than the old build thread.
    As @RacingMat has already indicated wiper motors are not a suitable choice for a 6DOF rig, if you created a low enough ratio actuator to take the load then the resultant speed would be way too slow for good motion.
  9. tadeusz
    tadeusz New Member
    34Coins
    hi
    thx Noorbeast
    I wonder is it impossible to support the weak force of spring / spring gas
    best regards
  10. RacingMat
    21,083Coins
    gas spring will slow the movements both ways... that's bad
    the only wiper 6 DOF I know is this one BUT it's 24V driven and short arms
    AND I far as I remember, the builder didn't keep this design and build something else (but not 100% sure)
    h
    made by zigzag49
    http://www.racingfr.com/forum/index.php?showtopic=50098
    sadly, pictures have disappeared
    153,986Coins
    +11,162 / 57 / -2
    @zigzag49's detailed build thread can be found here: https://www.xsimulator.net/community/threads/6dof-dc-24v-smolka-zigzag49.7490/
  12. tadeusz
    tadeusz New Member
    34Coins
    Hi
    I must consider
    Thank you very much for the good tips
    I think I have a bad idea
    The platform is to be used for flight simulators
    Do you have any tips ?
  13. tadeusz
    tadeusz New Member
    34Coins
    Hi
    Has anyone tried this solution?
    electric parallel connection
    one regulator
    one potentiometer
    best regards
  14. C1500
    C1500 Active Member
    1,119Coins
    AC motor, 6DOF
    Hi tadek
    Please keep in mind that the third PWM has not the fully frequency.
    I had a setup just like you but i used 3 Arduino.
    Do not save on an Arduino, you will only get more difficulties
    kind regards
    Peer
  15. tadeusz
    tadeusz New Member
    34Coins
    Hello C1500
    Have you used FLYPT?
    Does it connect via Arduino with the SMC3 batch?
    Best regards
  16. C1500
    C1500 Active Member
    1,119Coins
    AC motor, 6DOF
    Yes i still use mover and have used FlyPT´s former software.
    Works great for me with 3 Arduinos and SMC3
  17. tadeusz
    tadeusz New Member
    34Coins
    Hello
    I will try this concept:
  18. tadeusz
    tadeusz New Member
    34Coins
  19. tadeusz
    tadeusz New Member
    34Coins
    Hi
    C1500
    Have you tested
    layout with 2 Arduino?
    Do you think this system is better?
  20. tadeusz
    tadeusz New Member
    34Coins
