Converting the wipers engines of a 2dof platform into a belt tensioner system
Discussion in 'DIY Motion Simulator Projects' started by EduardoMoreira, Nov 15, 2020.
  1. EduardoMoreira
    EduardoMoreira Member
    113Coins
    After buying a 4dof platform I decided to use the wipersengines on my old 2dof platform instead of the servo motors on my belt tensioner. Unlike my old one, now the abdominal belt is also tensioned. In general the system became much stronger and quieter.
    Link YT videos:
  2. RacingMat
    21,087Coins
    nicely done! smooth and powerful :thumbs
    what are the specs of the motors, please?
    have you thought using the lateral belt in the other direction with lateral surge to make a 2DOF harness tensioner? this would give you more information
    I'm building a 2 DOF back tensioner (abdominal belt are not active though), only left and right shoulder are independant.
  3. EduardoMoreira
    113Coins
    Good night. as I only have two engines, I chose to tension the four points of the belt to have a more intense surge effect. I am using the following engine:
  4. Dan Aitcheson
    Dan Aitcheson Member
    New Zealand
    - 3Coins
    Your build has inspired me to scrounge some parts from work and implement this! I will document my build once my pots arrive and I have a weekend to tackle it!
    Thanks for sharing
